Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: Newbie From Perth Western Australia.
    Oct 2015
    Western Australia
    35
    Hey Everyone,
    Just secured a house with a pool. This will be my first time dipping my toes into pool ownership.
    Have done quite a bit of reading but im sure I will need the help and assistance of the fine people here so I have decided to sign up before moving into the place next week.
    I will update all of the details in my signature then.
    The pool is located in Sunny Perth, Solar Heated with a sand filter. There is quite a few unknowns as the house has been a rental for a while pool maintenance history is sketchy at best. I will get to pulling things down and making sure they are all of servicable quality once the move is done.
    Here is a pic of it.
    I look forward to learning and talking pools.
    Scott
    16000 Gallon In Ground Fibreglass Pool, Chloromatic ESC24PH SWG + auto Acid doser, Enduro EN-850 Sand filter Austral E Series 290 1.50hp pump, Poolrite EP1100 1.5hp Solar Pump with Aquatight V2D deluxe Digital Solar Controller, Pool Estimate build date around 2008. Taylor K-2006 test kit. Pool is filled via rain water as scheme water is not available.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,202
    Re: Newbie From Perth Western Australia.
    Welcome to TFP!
    You are ahead of the game in that you have a K-2006 test kit already. When you are ready to jump in the deep,end of pool ownership go ahead and start testing and posting results.
    One of us will be here to help.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,023
    Hi Scott,
    Welcome to TFP! Nice pool. Congrats on the new home!
    Divin Dave,
    Jul 2015
    Kentucky
    1,127
    Hi Scott, and Welcome to TFP,
    WOW, your pool is beautiful. You've come to the right place to learn the ins and outs of properly balancing, and maintaining your beautiful new pool. Once you get settled in, and are ready to start just let us know, and someone will be glad to help you. Again Welcome to TFP, and Congrats on your new home, and pool.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Oct 2015
    Western Australia
    35
    Me again, thanks for the nice comments so far will post more pics once I'm settled
    Now im going no to be about 35miles from my nearest store for supplies so want to do a shop as nothing has been left at the house and they have put the pool blanket on and it's been 35degrees C here for a couple of weeks I'm expecting I might have to SLAM once I get my test kit.
    So I'm planning to do a shop next time I'm in town.
    So far on my list I have
    Liquid chlorine
    hydrochloric acid
    salt
    soda ash
    stabilizer
    is there anything else I should get or is that going to cover me for most situations?
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    894
    Hi Scott, Welcome to TFP. Your just up the road from me in Bunbury. Sounds like you have things in hand- nice photo of the pool by the way. I've found Masters has the best prices for liquid chlorine-cheaper than Bunnings. Just check that the Liquid chlorine is not too old, ideally less than a couple of months old, which shouldn't be a problem with Masters as they turnover the stock fairly quickly (probably need to check that its not leftover from last summer). I find that with my SWG, my ph tends to rise over time so the HCL acid is always to have around as well as stabiliser. When you get a chance post some test results and we can see what's needed.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jul 2015
    Kentucky
    1,127
    That looks like a pretty good shopping list Scott. Since you are suspecting you will be doing a SLAM you might want to get several gallons of bleach. Be sure and check the date codes it will look something like this 15265 (which means the 265th day of 2015). Here is little calculator link that will tell what day of the year we are currently at. Today is day 285 http://mistupid.com/calendar/dayofyear.htm
    I hope this helps, and have a wonderful day.
    Oct 2015
    Western Australia
    35
    OK Here we go.. Now feeling a little overwhelmed haha.
    As Expected, Green soup. I have put the pump on manual to run constantly in the short term.. I was going to get some chlorine and start adding it daily until my test kit arrives but according to this chloromatic thing I dont need chlorine.. So confused.
    Info on the chlorinator https://epools.com.au/images/PDF/Chl...-20ESC24Ph.pdf
    Parts
    May 2014
    Franklin, NC
    9,202
    Nope, you need chlorine - lots of it.
    A chlorine generator if sized properly for the pool will generally produce sufficient chlorine to keep,a clear pool clear. It will not produce enough to clear up a green pool.
    Looking at the sales literature for your system it also dispenses acid to maintain pH, but,I,don't see what sensor they are using for the pH control.
    Support the site
    Oct 2015
    Western Australia
    35
    That's what I was realising after I read more haha. Sorry to be that noob asking those dumb questions.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP! Nice pool!
    Time to SLAM your pool to kill the algae, follow this process, Pool School - SLAM - Shock Level And Maintain
    Jul 2015
    Kentucky
    1,127
    When you start your SLAM you can shut your Chlorinator off during it, and just do manual liquid chlorine adds because as Tim said, it's not going to be able to supply you with the full amount you need during that time anyway, so you might as well help prolong your cell life by shutting it off.
    Also there's no such thing as a dumb question. If you have a question on Anything, regardless of how big or how small, please don't hesitate to ask because that's why we're all here is to teach you our method, and to answer any questions you may have along the way. Have a wonderful day.
    Oct 2015
    Western Australia
    35
    First order of business is to get the ph and salt right. Then I will start the slam.
    I still need to obtain a test kit since my supplier couldn't deliver. :/
    Jezza's Avatar
    Jan 2015
    894
    Hi Scott. You have got some green in there. Your chlorinator is very similar to mine although I don't have the Ph Feeder on mine. Are the lights flashing or green/red. I noticed that there is a red light on the PH status which by the looks means that the PH is too low or high. As already mentioned you are going to need to SLAM the pool which you are going to need a fair bit of liquid chlorine to be able to bring it up and maintain at shock level. BUT you are going to need to get that proper test kit so that you have all the ACCURATE readings to be able to effectively execute the SLAM. In particular you need to be able to get an accurate CYA reading to determine your shock level of FC for SLAM. The algae is consuming the chlorine faster than your chlorinator can produce it. I would put in a few litres of 12.5% chlorine daily to keep the algae at bay until you can get your test kit. Turn the chlorinator dial to MIN so that your chlorinator is not on as mentioned above but importantly your pump will continue to filter and circulate the water in your pool. Also closely monitor your pressure gauge on the sand filter, and watch for any dramatic increases, which will indicate that you will need to backwash your filter. Your gauge may even have an indicator which tells you to backwash (usually when it gets above 100. Although generally it is suggested to backwash when the pressure rises 20% from it starting clean pressure. Try and scoop out any insoluble material/debris/dead algae and brush the pool daily. But make getting the test kit the highest of priorities and read the relevant stuff in Pool School. You will get there. Good luck mate. Yell out if you need any more advice.
    K-2006
    Oct 2015
    Western Australia
    35
    24 hours of pump running and we have this..
    Thats a start.
    I have added some acid to the doser and set the ph to 7.2 lets see how that goes!
    Jul 2015
    Kentucky
    1,127
    Wow Scott, it's looking much better already. It's blue again.
    That's an awesome transformation in just 24 hours. Just keep dosing with chlorine, filtering, vacuuming as needed,
    brushing 1-2 times a day- (paying close attention to algae hiding areas i.e.-the light niches, steps, returns, skimmer, weir door, areas where the pool wall and bottom come together, etc.), and you'll have that beautiful pool cleared up in no time.
    Keep up the great job, and have a wonderful night.
    Oct 2015
    Western Australia
    35
    Yeah, I have added no chlorine currently as I had not been to the pool shop to get some yet. Im going to wait unit the PH settles and then start adding some.
    Since I dont have a test kit yet how much should I be putting in as a start? 1 gallon is 3.8Litres locally.
    Night.. Its only 11am and im still moving house no rest for me for a whole while haha
    Jul 2015
    Kentucky
    1,127
    Wow, no chlorine added in there yet, it's really going to start clearing once the chlorine starts being added. Amazing what 24 hours of filtration alone did for it.
    I would recommend adding a gallon of bleach a day until your test kit arrives, once it arrives then you can check your levels, and adjust accordingly.
    Keep up the great job, and have a wonderful "day" LOL it's 10:30PM where I'm at, but since it's 11 Am there, I suppose I'll say day. .
    Oct 2015
    Western Australia
    35
    Did another load of furniture up there and gave it a scrub.. Not a great idea in the midday sun.. No wonder you guys/gals with the big pools have a man who "comes to clean ze pool" But its looking nice and cloudy again. I will vacuum it tomorrow hopefully (its a competing priority at the moment.)
    Should I wait for the PH to level out or just start adding chlorine regardless?
  20. Back To Top    #20
    Jezza's Avatar
    Jan 2015
    894
    Get that chlorine in Scott- about 4 litres of liquid chlorine daily. Remember the aim of the game atm is to stay on top of the algae and not let it get any worse. I'm assuming your still running the chlorinator? As mentioned keep the brushing, vacuuming, pumping going but keep adding the liquid chlorine in.
    K-2006
