Results 1 to 8 of 8
Thread: Pool lights
    May 2015
    Fullerton, CA
    636
    Pool lights
    Getting into the final stages before signing a contract. Regular 110 pool light and spa light std, 3 of the Jandy muliti color nitchless led in the pool, 1 in the spa is a 1500 upgrade. This is a free form pool with a lot of curves. The larger LEDs nitched would allow for 2 in the pool one in the spa. Lighting might not be as good as the 3 nitchless. Suggestions?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Re: Pool lights
    Do you have a diagram of the pool setup?
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Sep 2015
    Mesa, AZ
    305
    Re: Pool lights
    I am starting my build next week and my contractor is really big on Savi Melody LED lights. Especially in free form pools with large tanning/baja shelves. Savi lights only need 4 inches of water. I am installing 4 in my pool. 2 for the main body and 1 in each baja shelf. Savi Melody P work with Pentair controllers.
    Freeform /620 Surface/110 perimeter/20k gal/ Raised bond beam/Baja shelf (2)//Pentair- Intelliflo VS pump, Pentair Whisperflo 1hp// Easytouch, C&C 520 Cartridge, Intellichlor SWCG// A&A- Magnasweep in-floor, LeafVac, Venturi Skimmer,// Mini-pebble (Aqua Blue w abalone shell)//4 Pentair Globrite LEDs//3 sheer descents//Travertine coping and decking.
    May 2015
    Fullerton, CA
    636
    Re: Pool lights
    That's the type of lights these are, can be put in 4" of water.
    Here is the basic design we updated it today, bigger Baja step that tie in steps near the house, equipment moved to side of house, more pavers, no planter wall at the rear.
    May 2015
    Fullerton, CA
    636
    Re: Pool lights
    This is closer to the new design. The Baja step will wrap in the steps towards the house. The curves on the pool are more like the top design. Rear planter wall being replaced by a 6 ft wall like the wall on the right side
    Jul 2015
    Kentucky
    1,126
    Re: Pool lights
    That's going to be so pretty, and I really like the design changes you made. I'm looking forward to watching the build.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Re: Pool lights
    I recently changed out my 300 watt incandescent screw in type pool lights to Screw in replacement LEDs. I have my two 110v niches in the pool and one in the spa lit up now by Bulbwizards Pool bright bulbs at $169 each (Amazon). A real bargain over similar lights costing $100 more. Excellent reviews so far.
    The old 300 watt lights were an overkill-washed out my landscape lighting. These LEDs put out less light. I did find them to be a lot more uni directional than I expected..., more like a narrow flood light than a wider flood effect. The two are installed on the pools curved right side, i.e. on each side of the "bump out" created from my joined spa. As you can see from the picture, these locations created a darker area in the middle; but I found this to give a very interesting look to the pool, vs having the entire pool washed in the color in a uniform manner. The only downside was that the Baja shelf does not catch the light much. Would be cool if I had the savi small led for just the shelf. As for my spa, no problem... The single Bulbwizrd light it up completely.
    Ive seen some mixed reviews with the nichless LEDs, but hard to say whether there is a large enough sampling of reviewers to get a reliable record going on these nichless lights.
    Needless to say, Lighting is a big part of the design, so do as much online research as you can. I also find that looking at manufactures brochure pics can be a little misleading as to what yours will look like. Would obviously be a huge advantageous your PB can refer you to pools in your area with these lights. (Heck, I drove an hour away to see a pool finish before choosing what I ended up with).
    Cheers.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    May 2015
    Fullerton, CA
    636
    Re: Pool lights
    Thx, looking to do the same thing.
