Results 1 to 18 of 18
Thread: Homemade Solar Mats
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    Homemade Solar Mats
    Split from Pool Heating Solution for Florida ?
    I just use clearance one ring baby pools at .50 a pop. Keeping my pool in the upper 70's n 80's. Cost a whole 7.50$...: ) same technology as the solar mats that range from 30-50$.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Pool Heating Solution for Florida ?
    How much do they blow around and out of the pool?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    Quote Originally Posted by pabeader View Post
    None have blown out or in since i got them 3wks ago. When we swim they stack up on the deck n then toss em back in when done. Only thing is we had to re blow a few as some leaked air out of the nozzle. Still working to heat the pool so I don't mind. Solar blankets can be dangerous if you fall in one you get sucked into it n cant get out.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Hate to hijack this thread, but you got any pictures? JumboJet might be interested also...
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    I do have pics ...
    As you can see here the air pockets in the expensive one 40$ are the same as the baby pool .50 .The pockets absorb heat n release it into the water. The same technology at work here. The darker the better.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Homemade Solar Mats
    Well now I gotta go check out local stores to find those.
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    After summer sales are the best time... hope you find something that works. Think outside of the box on this one.. : ) bubble wrap would prolly work for a solar cover cheaper as well...
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Good Idea!
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,245
    Quote Originally Posted by Lou. View Post
    Did you order these on line? If so, where did you purchase them? Otherwise, what exactly are they called? Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    Walmart in store after summer clearance . Just any baby pool will work so long as it has air pockets in its bottom. Even if they are 5-10$ still much less than 30-40$. If not this year than the next. I haven't looked into bubble wrap but you might find it at office supply stores. Happy hunting.
    Catanzaro's Avatar
    Jul 2014
    2,245
    I thought they were floats, not baby pools. Makes sense now. Thanks!
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    BRILLIANT!
    I see you're in TX.
    Any idea how much heat they provide - What would your water temp be without the mats/pools, and what is it with?
    20x40 in-ground concrete "vintage" pool
    Approx 35k gal
    Concrete, plaster and epoxy paint
    Sand filter
    DIY plaster resurface repairs completed 6/2015.
    Household6's Avatar
    Sep 2013
    Fayetteville, NC
    296
    Quote Originally Posted by Catanzaro View Post
    Floats have air pockets that are long and skinny. Is the key that the pockets be fairly small, or would a float also work?
    I surmise the pools would be better as they can hold a small amount of water in them to act as a weight and keep them from blowing out. But what if a string with something lightweight attached was tied around a float. Would that work?
    Approx 35k gal
    Sand filter
    Jul 2015
    Valley Center,KS
    1
    A friend of our's in OK uses hula hoops inside of black trash bags. He claims it works well.
    18 X 38 Vinyl 16500 gal.
    SWG IC-40, Intelliflo Variable Speed 3HP Pump,
    Pentair TA-60 SandFiler, Pentair UltraTemp 120 Heater,
    Booster pump with Kreepy Crawler pressure cleaner,
    Swim Jets, CoverStar cover.
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    When experimenting I measured temp from sunrise to sundown with just sun n pool temp changed maybe 2'. With baby pools in I got 6'. Note my neighbors pool yesterday was at 74' with nothing n mine at 80' with baby pools. Keep in mind my plaster is a dk blue n theirs is light. Yes I think a lil water in them could help with blowing around yet I haven't had any issues. The pools kinda stick to the water.. shrug. Floats may work, the thinner the better. Household6 good way to think outside the box. I assume that a tarp weighted or floated with string like you said should work. Would keep heat, water n chems in the pool. Hula hoops are a good idea so long as they hold up n you don't mind the look.
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    aha Redneck solar cover Good ideas
    Overnight heat loss being my biggest enemy.
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    I should add the baby pool solar mats took a few days to heat up the pool...
    Pes0611's Avatar
    Oct 2015
    North Richland Hills, Tx
    43
    Im going to try this this summer.
    18k gal, IG Blue Granite Pebble Sheen, Jandy CL460, 2 Variable Speed Pump Jandy-VSPHP270AUT, pool build 1/25/16, A&A In-floor cleaning system, Sanitizer-Nature II-Fusion-Cartridge, Sanitizer-Ozone-Dell-MDV-VSpd., A&A-QuickSkim-Venturi-Skimmer, A&A-LeafVac-Debris-Cannister, Rain-Fall-6ft-White-Custom-Cascade
