Thread: Is it OK to close pool with cloudy water?
    Apr 2014
    United States
    21
    Hi, September was a busy month and I didn't get to maintain my pool as much as I would have liked, and algae built up. I swept out what I could through waste, but the water was green. I shocked the pool, then ran algaecide and the water is no longer green, but is cloudy. I can see the bottom of the pool so it's not super cloudy, but I was wondering if I should still continue to make the pool clear (maybe with some clarifier?) before closing. I am going to use Robelle winterizing kit (which worked great last year).... any suggestions? Thanks!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Re: Is it OK to close pool with cloudy water?
    Please add your signature and possibly location of which State you are located in. It is best to clear up the pool prior to closing. If it is cloudy, then you still have issues that have to be cleared up. It is best to SLAM at this time and close the pool properly. This will help in the spring, in case you wait a little too long and then open up to a green pool.
    Additionally, how are you testing your water? Can you please post a full set of test results. Thanks!
    Here is some reading information:
    Pool School - Pool School
    Pool School - Defeating Algae
    Pool School - Handy Reference
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Apr 2010
    Central NJ
    227
    It would be best to clear up your pool now and have less issues when you open it. Clarifier? No need for that! Read the pool school and start the SLAM process get it clear and then close it.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
