Thread: 12V LED Strip lights under the lip of the pool - Bad Idea/Non Code Compliant?
    Aug 2014
    Jupiter, FL
    6
    Post 12V LED Strip lights under the lip of the pool - Bad Idea/Non Code Compliant?
    Greetings All,
    I saw some cool LED strip pool lighting like the this: https://www.youtube.com/watch?v=cT4VPrvc5rE
    However, thinking in my situation adding led lighting to a pool via surface mounted conduit - it probably not code compliant/safe?
    My situation/idea:
    - Wiring to current underground lighting to the in ground pool looks to be severed somewhere (Was like this before I got the place last year) - bypassing this entire setup
    - Idea to get LED strip to pool
    - Get a 12V "pool safe" transformer connected to a GFCI outlet 15' from the pool
    - Run the 12V lines in surface mount conduits to the pool
    - Run the 12v line to under the lip of the pool in a flexible cable track - like this: http://www.homedepot.com/p/Wiremold-...DI-5/100095586 - would use pool epoxy putty or other adhesive to hold the track down and use clamps while it cured in the C shape it needs to make to get over the pools edge and under the pool lip -- seeing this part typed out makes this idea look really really horrible......anyway on with the train wreck....
    - run the IP68 LED strip lighting under the pool lip - and either adhere it every 3" with epoxy pool putty (held down with clamps until cured) or use the plastic clips and find some what to attach those to the concrete underside of the lip.
    Really bad idea right?
    Oct 2014
    Villa Park, CA
    52
    Re: 12V LED Strip lights under the lip of the pool - Bad Idea/Non Code Compliant?
    Quote Originally Posted by Pool_Bob View Post
    Yes.
    LED strips around the pool edge?
    20' x 40' 30,000 gallon IG Plaster with Spa, wading pool, fountain built 1993
    Pentair 011018 IntelliFlo / 2HP fountain pump / 2 HP spa jet punp / Jandy Ji8000 controller with IntelliComm II interface to IntelliFlo
    Crystal Water Aqua Clean 60 Sq ft DE filter / FlowVis Flow / Stenner DIY Chlorinator / The Poolcleaner 4-wheel / Taylor K-2006
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    It's done all the time. Many posts here with pictures and videos. Just be sure to waterproof all connections.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    There are LED strip light kits made for pools. Many of them are designed to be submersible.
    Love TFP? Become a
    TFP Supporter!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    There's also fiber optic light kits that offer lighting without any risk of electrics under water.
    A friend of mine gave me his made for a spa with extra long fiber rope. same application.
    The main box with a halogen sits in the equipment room then the fiber is laid out in the pool between
    coping and pool with black out tape on the part before its in the pool.
    Dolphin E10 Cleaning Robot.
