Results 1 to 8 of 8
Thread: Safety Products - Pool alarm
    Wasn't sure where to post this, couldn't find much on it.
    I have a little one 2 years old. We have a fence and we have a gate on the deck but I'm looking into these pool alarms. Do they actually work enough to be worth the money? If so can anyone recommond one? I read some good info on a Swim Alert unit?
    Thanks
    Vince
    46k gallon vinyl, Intelliflo VF, Quad DE 100, Autopilot DIG60, Raypak R405a, Bravo Fury Auto Cleaner
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Safety Products - Pool alarm
    IMO safety alarms are only good if you hear it go off !!
    There is no better safety than a LOCKED gate and a well supervised child. I think if she is old enough that you are concerned then she is old enough to start with the pool rules .....
    A better buy for your money would be to enroll the child in a swimming course that teaches children what to do should they fall into the pool to prevent them from drowning.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Ohio
    217
    Vinnie...I have tried the pool alarms and I didn't have much luck with them. They might have better ones now but mine would give false alarms every day no matter what setting it would be on. You need to check your pool codes there is some states that require them I have read.
    My set up is similar to yours. 5' gates have the magnalatch at the top and a gate on the deck with a combination lock. I also installed chain locks and bolt locks at about 5' on my inside house doors and sliders. This helped me sleep at night.
    I agree with TizMe 100% supervision is a must at all times. and teaching the kids to swim is important. My daughter has swam since 18 months. I have found I had to teach my daughter to swim every year. She would forget in the off season. She will turn 5 this week so I will see if she remembers this year soon.
    Ric
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Ric, Our older Grandchildren seem to get the hang of it every year but they seem to need a little coaching in the beginning every year the past couple of years. One is 8 and one is 7.
    They soon remember though !
    Les
    Helpful Links:
    May 2008
    Virginia Beach, VA
    84
    We have a Poolguard inground alarm. I am happy with it.
    It has an AC powered in-house receiver for the alarm, which you definitely hear! The unit itself has a 9 volt battery which I replace every season.
    I haven't had much trouble with false alarms. Usually it happens during a storm, especially if there has been a lot of rain that has raised the level of the pool. I try to reset the unit during or after a storm before I go to bed to minimize that chance (I think I've only gone running out in the middle of the night in my underwear once to silence an alarm.. great visual).
    It can be picky about being removed and then put back in the water, in terms of having the alarm go off. You're supposed to hold the button for 5 seconds, hear a chirp, and then you have 5 seconds to put it in or take it out, but sometimes it goes off anyways. Usually just holding the button will shut it up (but not before my wife comes running from the house!).
    But overall I'm happy with it, in terms of not having many false alarms. This is should only be one layer of protection as others have noted, and the best protection is as many different layers as you can do (door locks, gates, alarms, net, safety covers, education, etc).
    Virginia Beach, VA
    28K inground, vinyl
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    I also have the Poolguard alarm. I unfortunately don't use it anymore because I had too many false alarms with it and waking up the neighbors in the middle of the night is not something you want to do too often.
    I'm considering modifying it with a remote control relay switch so that I can cut it off from inside the house. I might also unplug the speaker in the outside unit and just keep the remote alarm speaker that is in the house. It will still wake me up, but not the entire neighborhood.
    It's big compromise on security, but it's better than not using it at all.
    Of course, this is all additional security, the pool is enclosed with a 5' fence.
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Check out this link to the Pooleye Alarm models: http://www.smartpool.com/website/pooleye23.html. They are reasonably priced, but, of course are just one layer of protection for your pool safety. Some of the old systems that used lasers and mirrors have been discontinued because of liability issues...if the wind (or a dog, or bird, or kid) knocks the reflective device out of position, the perimiter security has been destroyed. Floating pool alarms (like the old Remington) have not proved effective.
    Agreed, the best defense is supervision and "drownproofing" courses for children. The human body will float, even if just a few inches below the surface. With proper training, no human should drown in a swimming pool!
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Jun 2008
    Bruce Peninsula - Ontario
    44
    Hi, i am a dealer for this product and have been using it at the entrances to our pool it works very well no faults alarms and the battery lasts a long time over one year and still working! I don't want to sell you one but if you contact any garage door dealer in your area they will have a source to order it under 100 bucks. Every time it goes of my dog goes postal I don't need to worry about not hearing it! http://www.chamberlain-diy.com/doityour ... ?typeid=59
    20 X 40, 28000 gal IG cement bottom, steel sides, vinyl liner, Pentair 4X160 pump, sand filter, SWG, Titan heat pump, coluorlogic and fiber optic. concrete-exposed aggregate deck
    1 skimmer, main drain, 4 returns ( 2 in stairs ) JEWEL LIKE WATER thanks to TFP!
