Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Solar Panel Question
    Oct 2015
    Tampa, FL
    7
    I recently purchased a home with solar panels. At my first attempt to use the system there were multiple pinhole leaks in one of the panels.
    This particular panel brand (Vortex) can not be plugged, and is considered a "throw away" panel once damaged. I find it hard to believe there is no other way to plug the leaks, so I was hoping someone could help. I have read other posts regarding this matter, and there isn't that much info out there. There are several threads about epoxy failure. Some have recommended a plastic welder, but that is a little above and beyond what I can accomplish.
    I read something about drilling screws into the panel, but I'm not exactly sure what that meant or how that would seal the leak. Any insight into that or any other methods would be truly appreciated.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Solar Panel Question
    If you had a screw with a soft rubber foam type washer, you could screw in where the hole is and it would seal around that screw. At least that's the theory. They are used in constructing greenhouses with that corrugated clear plastic for roofing.
    An idea how old they are? Warrantied for 10 years.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2011
    Long Beach, CA
    2,780
    Welcome to TFP!
    The easiest solution might be to buy a replacement panel as those panels are very difficult to repair.
    As Bob said, check to see if they still have a warranty.
    Oct 2015
    Tampa, FL
    7
    Quote Originally Posted by ping View Post
    Welcome to TFP!
    Yes if it comes to that, that is what I'll do. The only good thing about an off brand like Vortex is the panels are only 225 each (as opposed to 500 for Fafco).
    I guess I'm just a little baffled that a pinhole leak can take down an entire panel with no solution. I'm a new pool owner, so if that's what it is that's what it is.
    ..and to the previous question...I bought my house from a corporate relocation company with ZERO info about the house. It was an "As is" situation which explains why I didn't really test it out too much before hand. I called a local solar company and they said they serviced my panels in 2005...the house was built in 1994...they may be 20 years old for all I know...oh and Vortex's warranty is not transferable.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I used small metal screws on mine but it was fafco.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Did you use stainless screws?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The Vortex panels are private label version of the Techno Solis panels which just happen to be made in Tampa, as to patching them multiple people have had success on here using plastic welding techniques using a bit of material from one sacrificial panel to fill in for the missing material. Being In Tampa you might even be able to get a bit of scrap material or a damaged panel from the manufacturer.
    see these threads on the topic
    Solar Panel repair
    First Solar Panel Leak After 6 years
    Ike
    Oct 2015
    Tampa, FL
    7
    I'm not discounting the weld method...I just don't have the equipment or knowledge. With the screws are you talking about screwing them directly through the panel itself? Will that still work if Vortex are square tubes instead of round? Did you coat the screw in liquid nails or caulk? Or are you talking about bypassing the tube by screwing into the header?
    Thanks
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    It's an old plastic pipe trick. You use a short, small screw with a large flat head, (not tapered). Just screw it in right into the pin hole. Assuming that the leak is just a pinhole or so in size. You use the screw to plug the leak not the whole line.
    Oct 2014
    San Antonio, TX
    449
    For metal roofing they sell screws that have a rubber grommet on the under side of the head. Wonder if you put some silicone caulk on the screw and then carefully tighten it. Would that stop the leak?
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    Jun 2014
    Roseville, CA
    343
    I would use a "not to big" stainless steel screw coated with silicone. Give it 24 hours to cure.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Oct 2015
    Tampa, FL
    7
    Sorry for being so confused about everything, but let's say the screw did stop the leak...what happens to the water? If I'm screwing the screw all the way through the panel aren't I blocking that particular tube? Does the pressure of the water still let it pass, or does it redirect through other tubes? Sorry if that's a stupid question
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    No, the screw is only like 1/8" or maybe 3/16" long Not anywhere near the width of the panel. We are talking pinhole repair here. Not big holes. Big holes are a whole different beast.
    Just through the thickness of the individual tube.
    Oct 2015
    Tampa, FL
    7
    I went to Lowes today and the shortest screw they had was 1/4". I bought a pack anyway, but after eyeballing realized they were too long. I'll have to buy online, or maybe Ace Hardware.
    ...what are the thoughts on trying this method without silicone? The only reason I ask is because I have several pinholes, and it is close to impossible to mark the exact spot and expect the mark to be there after drying. Is the screw enough or is it all about the silicone?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I Tried hot glue first with no luck. Like you, I didn't want to plug the tube like manufactures kit does. I used screw from old broken glasses that hold nose pad on. It may have been stainless. I'm talking about a very small pin hole. Hope that helps.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Ps, I didn't use silicone. It held for couple years before wind storm ripped entire panel of my roof. I think those little screws Walmart sells for eyeglass repair kits are stainless
    Oct 2015
    Tampa, FL
    7
    Ok...got some small screws...turned the pressure back on to the panels to mark the leaks...and more pinholes than before. One new one is pretty impressive at the seam. And now the 2nd panel has a pinhole leak. I appreciate everyone's advice, but I'm guessing these panels are toast. You guys think I should replace them myself (seems easy enough), or pay a company to replace them? Also, should I replace the broken panels, or just bite the bullet and replace all 6?
    I contacted Solar Direct, which seems to be the only company that stocks Vortex, and I can buy 6 panels for 1350 and do it myself, or 2700 for them (probably a sub contractor) to install. The other option is go FAFCO with a different local company, but I know they charge about 500 for each panel...
    Thanks in advance
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Since you are in Tampa I would suggest calling Techno-Solis direct and see if you can get a good price buying them and picking them up at the factory to avoid crating and shipping charges. They are the exact same panels, Solar Direct buys the Vortex panels from Techno-Solis and sells them under the private label Vortex name which lets Solar Direct have their own warranty terms, etc. This is fairly common practice in the pool solar panel industry, and lets the same panel be sold through different distribution systems with dealer installs, DIY, etc. at different price points with different levels of support and warranty coverage. In the case of the Solar Direct Vortex panels, they are limited to certain sizes, and I think only have the 1.5 inch header option, where you can also buy the Techno-Solis with 2 inch headers and even in custom lengths.
    Ike
    p.s. correction they are made across the bay in St. Petersburg
    301 20th St. South
    St. Petersburg, FL 33712
    United States
    Phone: 727.823.6766
    888.99 SOLAR
    Fax: 727.823.6768
    info@techno-solis.com
    banditig's Avatar
    Sep 2015
    Ohio
    466
    They haven't updated the website for many years (techno-solis). Fafco seems to to be.
  20. Back To Top    #20
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Banditig, So? The page info shows it was last updated in 2011
