Thread: Pool Store whirlwind, i want to test everthing
    Oct 2015
    kzoo, MI
    2
    I've tried trusting the Pool Stores and am ready to get off the try 20 different chemicals roller coaster. What do I need to be able to do all my own testing for both my pool and hot tub? I am using bromine in the hot tub and a SWG on the pool. I'm confused between the different test kits and if only 1 kit will cover everything I need. I have started reading the TFPC philosophy.
    33' round x 54" Resin AGP 26k gal, Intellichlor IC40, Hayward pump with DE filter, beaded liner, enclosed with deck.
    Lazyboy Refresh Hot tub, bromine
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Pool Store whirlwind, i want to test everthing
    Welcome to the forum. Hard to beat the TF-100. An article in Pool School compares the recommended test kits for you.
    Jun 2014
    15,178
    Hello and welcome to TFP. Good choice on your own testing. I'm with Woody on the TF-100. This should help you:
    - The TF-100 (link below in my sig) will cover everything for your pool and even help to test bromine in your spa. You can use the FAS-DPD chlorine test portion of the TF-100 and just realize that when you are testing Free Chlorine (FC) in that test that you are really testing Total Bromine if you multiply your result by 2.25. Here is a great discussion on that subject: Testing bromine?.
    - Since you have an SWG, you'll need to test for salt separately. You can get the kit for that at the same web site here: TFTestkits.net
    If you're curious, here are the test kits compared: Pool School - Test Kits Compared. I have the TF-100 and love it. Make sure to ask for the speed stir to help you mix like a pro. Hope this helps.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi hillard,
    congrats on your decision to take control of your pool. In addition to the TF100 already mentioned, if you care to test the salt level also which teh TF100 doesnt cover, then I suggest adding the Taylor K1766 salt test kit to your shopping list.
    Divin Dave,
    Oct 2015
    kzoo, MI
    2
    Thank you for the help! Testing supplies are in and I've been reading more threads on TFP. I feel like I'm finally on the right track to cut the pool store umbilical cord!
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Welcome! Post some results after you get done with the tests!
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
