Thread: Pool lights and algae
    tdp's Avatar
    Sep 2015
    Suburban Philadelphia
    57
    I had an algae problem about a month ago and SLAMed successfully. The pool looks great now, but I can see some brownish stuff in my pool lights.
    Can I remove the lights while they're under water (after shutting off breaker, of course). Don't want to electrocute myself next year when I turn them on again BTW, they are PAL led lights. Thanks!
    ~17,500 gal. IG Fiberglass, Viking "Cambridge"; installed 6/2015
    SWG Hayward Turbo Cell T-9
    Hayward Hi-Rate Sand Filter
    Hayward Max-Flo XL pump
    TF-100 Test Kit/SpeedStir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Pool lights and algae
    If you see things behind the lens they really don't contact the water.
    But, in answer to your question yes, you can remove the light. The bulb is enclosed inside a sealed unit so removing it from the wall is safe. There should be sufficient cord length behind the light to allow you to bring it up onto the pool deck for service when you remove it from the wall.
    If you need to open the sealed unit understand that there is generally a gasket between the lens and housing that holds the bulb. Most manufacturers recommend replacing this gasket if you open the light. Figure somewhere in the neighborhood of $15 for a new gasket.
    Support the site
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Be ready for a plume of yuck to come out when you do this. Some folks will have their vacuum hose ready to suck up whatever comes out. This is usually a suggestion made during a SLAM so the elevated FC can get in there and kill off anything still trying to hang on.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    tdp's Avatar
    Sep 2015
    57
    Oh, if I go in there, I'm gonna have some old clothes, a bucket of bleach, and a toothbrush at the ready )
    May 2014
    Franklin, NC
    9,184
    The area behind the light is flooded right now, so don't worry about the bucket of bleach and toothbrush. Just opening it up will allow the higher chlorinated water in and clean stuff up. But, as Bob said having your vacuum sucking before you open it will get rid of a lot of the junk.
    Support the site
