Thread: Acid wash de grids
    swirlywater's Avatar
    Feb 2015
    columbia station / OH
    63
    Acid wash de grids
    If I use ph- powder for the acid wash recommended here in a 10:1 mixture, how much do I add per gallon of water?
    20x40 30k gal vinyl, Inline Tri-Chlor Chlorinator, Hayward 250K btu heater, Hayward 2HP Super Pump, Hayward DE6020 Filter,
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Acid wash de grids
    Can you provide a few more details about exactly what you're using? What pH powder do you have? Throwing out "10:1", it sounds like they want you to dilute your acid by like 90% (actually, a bit more since it would be 10/11 but 9/10 is easier to do in my head sitting here) but what assumptions are they making about the kind or strength of acid to use? You might search here on 'acid wash de grids' and see what you find.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jun 2015
    Wildomar, California
    423
    Why would you not use muriatic acid for your acid wash? Much easier and a better job.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Before you acid wash the grids you need to de-grease them first.
    Quote Originally Posted by Waste
    To chemically clean the grids/ nest:
    1) Have a bucket/container large enough to hold the entire assembly - A large plastic garbage can works well.
    2) #1 Add some TSP (tri-sodium-phosphate) to the water or some electric dishwasher detergent to the water and soak the grids for at least 3 hours - this will "de-grease" the membranes and is the first step in cleaning them, rinse with hose and get ready for step 3.
    3) Dump the container, refill with water and add muriatic acid to the water so that you have a 10:1 water:acid mixture and soak the grids for at least another 3 hours, this will clean any calcium off of the grids. Rinse grids again and reinstall them in the filter.
    4) Now, run pump and bleed off the air from the filter and add 100% of the DE the filter calls for.
    Love TFP? Become a
    TFP Supporter!
