Results 1 to 9 of 9
Thread: Main Drain cover
    Oct 2015
    Sydney
    5
    Main Drain cover
    Dear TFP,
    I just drain my swimming pool to resurface it and I have found this at the deepest in swimming pool, I am not sure what it is as show in the photo
    I am thinking it is main drain and I am unable to dry this area around it because the water keep running out from it.
    Anyone know how to open its cover to do sth to make this area dry?
    Much appreciate all your advises,
    Kevin.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Main Drain cover
    Hi, welcome to TFP! It could be a type of hydrostatic valve under there that allows ground water into the pool so it doesn't "float" out of the ground when you have a high water table. If an area is known to have a high water table then the pool builder will often include a means to relieve the pressure on the pool shell if you drain when a lot of ground water is present. Has there been a lot of rain in your area lately?
    Love TFP? Become a
    TFP Supporter!
    Oct 2015
    Sydney
    5
    Do you know how to open its cover? I tried to lift it up also turn it but it's tight really hard. Also I can't see any screw or sort like that as you can see on photo.
    I need to dry this area before I can resurface the in-ground swimming pool.
    Cont -
    Also another question, why the water keeps comming out from it, how can I stop it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Water keeps coming out of it because there is water under the pool. If you try and stop this, the pool may come out of the ground which would be a disaster. Are you refinishing the pool or hiring it out? What type of refinish are you going with?
    Mark
    Oct 2015
    Sydney
    5
    I just want to paint its surface. Need the pool dry to do that but the deepest area is wet because of that.
    Jun 2014
    Roseville, CA
    343
    Is there a dryer time of the year you can do this?
    The worst thing in the world is to have your pool lift. It is a disaster.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Oct 2015
    Sydney
    5
    these days are very hot here. However, water at deepest area stop me to paint. I pump it out and it comes out almost right away.
    Any ideas how to paint?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I believe there is an epoxy paint that can be applied under water. Something you might want to research.
    Mark
    Oct 2015
    Sydney
    5
    Thanks guys for your info. I have refilled the pool w/o painting.
    My local pool store said the hydrostatic valve part that I am using is not stocked anymore and if I break it, I need pro to fix.
    Cheers
