Trying to find a propane heater set-up. Does anyone have any recommendations or awesome set-ups they can share? Thanks!
Intex swimming pool
22 feet wide by 56 inches deep [10,500 gallons salt water]
Sand filter [Holds 120 lbs. of sand]
0.95 horsepower pump
Half is sunk into the ground, the other half of the pool is above ground with a deck built around it. There are green boards lining the outside of the pool and is backfilled with pea gravel to make a French drain around the pool.
Intex swimming pool
