Thread: Any Propane Heater Set-Ups?
    Trying to find a propane heater set-up. Does anyone have any recommendations or awesome set-ups they can share? Thanks!
    Intex swimming pool
    22 feet wide by 56 inches deep [10,500 gallons salt water]
    Sand filter [Holds 120 lbs. of sand]
    0.95 horsepower pump
    Half is sunk into the ground, the other half of the pool is above ground with a deck built around it. There are green boards lining the outside of the pool and is backfilled with pea gravel to make a French drain around the pool.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Re: Any Propane Heater Set-Ups?
    Seems to me, propane would break the bank in trying to heat a pool.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Depending on how often you use it etc, propane won't break the bank.
    I would suggest you look at a Raypak 200K BTU or a 266K BTU. Raypak is the best unit on the market today.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
