Thread: Draining Pool below returns - Is this a problem?
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    I have a small 3/16" per day leak in my vinyl liner pool. I am getting ready to close, I just drained the pool an inch below the skimmers and still have the 3/16" leak. I do not believe it is the plumbing as I sealed all pluming except for the drain and still had the leak. I know you can drain vinyl pools too far...what I want to know is this...
    1. Is there a problem with draining below the returns? - Trying to rule out that the place where the return connects to the liner is/is not the culprit
    2. I read here that 8" above the shallow end is about the farthest you can go, definitely stop if the walls start to pull away. How far does TFP recommend is the max?
    Thanks in advance folks...
    Owner since August 2014. 21,500G Liner In ground Pool with attached 600G plaster in ground hottub. TF-100 Test Kit, Filter: Pentair TA60D Clearpro Sand (HTH) Filter. Pool: 1 Drain, 2 Skimmers 4 Returns. Hot Tub: 1 drain, 1 skimmer, 2 returns. Hot Tub/Pool run by Sta-Rite Dura Glas Single Speed 1.5hp P2RA5F-182L pump with Emerson K63CXESE4972 motor. Spa jets run by Sta-Rite Dura Glas H/L model number unknown.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Draining Pool below returns - Is this a problem?
    Hi, I just read in pool school you can use food coloring to help find leaks. maybe try that around returns?
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    I have done that, I just need to know how low I can drain and if past the returns is ok. Thanks though.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Any help with how far is the max you should drain a liner pool?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You can drain a vinyl lined pool as low as leaving 1 foot of water in the shallowest part of the pool without risk of the liner shifting. However, if you have a high water table around the pool or have recently gotten significant rainfall, lowering the water level could allow some water in the ground to seep behind the liner and bubble the liner inward. This is usually only a problem in low lying areas after significant rain fall or pools with poor drainage around them.
    Isolated Spa - 345 Gallons
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Thanks, will be careful with the lowering, if I find it now, before closing I don't have to worry about it this winter.
