Thread: Algaecide 60% Non-Foaming - added to pool,drain off 6 inches into pond with fish?
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    I wanted to get my algecide into the pool and run the pump for 24 hrs, so I've added it. Now I am going to drain off about 6-10" to get below skimmer intakes (to winterize)
    Will it be ok if I drain that water into my near by pond with fish in it? The pond is about 1 acre in size so I wouldn't think it would be a problem but I don't want to harm my fish. Otherwise, I will have to drain it down into a shallow ditch between my neighbor and I and I don't want him upset.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Algaecide 60% Non-Foaming - added to pool,drain off 6 inches into pond with fish
    What is the specific algecide used? Make/model/contents?
    Are there any warnings on the bottle?
    My gut reaction would be not to drain intoi the pond with fish, but that is just me. Not only the algecide but chlorine is toxic to fish.
    Support the site
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    And it really isn't good for the beneficial algae and bacteria in the pond.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Dw9000, I too am worried about upsetting the ecosystem of the pond.
    But just so you know, my pool tech closes without draining using duck plugs and a gizmo in the skimmer. I'll try to dig up the link to the gizmo that lets you blow out the lines with water in the skimmer and post it in case you're interested in this approach -- assuming you don't have waterline tile or anything that could be damaged by ice.
    Blowout Skimmer Guard - Winter Pool Closing Accessories for In-Ground Pools
    Amazon.com : Anderson WDP150 Winter Duck Plug : Swimming Pool Winterizing Chemicals : Patio, Lawn Garden
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
