Results 1 to 8 of 8
Thread: CYA after storm
    Sep 2013
    Charleston, SC
    540
    CYA after storm
    I did a complete battery of tests after the 15" of rain and five drainings to keep the pool from overflowing and they are as follows:
    FC 6.5
    CC .5
    PH 7.2
    TA 50
    CH 200
    CYA 60
    I added borax and baking soda last night and will add Calcium tonight.
    My question is, should I increase my CYA or leave it and increase next spring? I am not closing the pool and I don't cover it for the winter.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: CYA after storm
    I would maintain as it is and see how your chlorine usage is during the fall/winter. Easy enough to bump it back up in the spring. What was your CYA at before?
    Isolated Spa - 345 Gallons
    Sep 2013
    Charleston, SC
    540
    Re: CYA after storm
    Quote Originally Posted by JVTrain View Post
    My CYA was 80 before.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: CYA after storm
    I agree with Joel, why mess with it. The other numbers above, were they before or after borax/baking soda?
    Support the site
    Sep 2013
    Charleston, SC
    540
    Re: CYA after storm
    Those were before any additions. I added enough borax to raise PH to 7.7 and enough baking soda to get TA to 70. I will add enough calcium this afternoon to get to 300.
    May 2014
    Franklin, NC
    9,193
    Re: CYA after storm
    Quote Originally Posted by otter86753 View Post
    Does your pH tend to rise on its own? If so you may just let it slowly drift up.
    As long as your numbers are in range, don't get too fussy for a specific magic number.
    Support the site
    Sep 2013
    Charleston, SC
    540
    Re: CYA after storm
    My PH usually is rock solid with no increase or decrease. I keep my TA at 70 as that is where my pool likes to be to keep my PH steady. I'm increasing my CH to 300 to help with my CSI.
    May 2014
    Franklin, NC
    9,193
    Re: CYA after storm
    Excellent!
    Support the site
