Results 1 to 7 of 7
Thread: Saltwater chlorinator timer intermittently not providing power
    Oct 2014
    Australia
    32
    Hi,
    My wife and I have an “Onga RP3000SC” as our saltwater cholorinator.
    It is currently set to run 8am – 10am and 2pm – 6pm.
    Yesterday I noticed that it was 9am and I could not here anything running. I went out and had a look at the chlorinator and the timer dial was correctly showing 9am but no power was supplied to the chlorinator/pump. I gave the timer face a gentle tap with my finger and everything powered up (and I flicked the switch to manual until such time as the 2 hours had been “caught up”).
    I have the owners manual but it doesn’t have a great deal of troubleshooting information in it.
    The above issue is intermittent, most days it starts up at 8am/2pm just fine and shuts down when it should.
    Perhaps there is a simple way to remove the timer face and give everything a good clean (if that’s what the problem is)?
    Cheers.
    Jun 2011
    Long Beach, CA
    2,788
    Re: Saltwater chlorinator timer intermittently not providing power
    It sounds like you have a bad connection somewhere. I would turn off and disconnect the power and then make sure all power connections are cleaned and tightened. There might be some corrosion on a connection over the winter.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Could you post a few pictures? I can't seem to find that model in the Googlesphere.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Oct 2014
    Australia
    32
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    thanks, that should help us finding out about this.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    From what I can see, I bet the timer needs service. Since it's mechanical, you might be able to clean it with some compressed air like for cleaning computers. It sounds like the switch contacts are dirty or have stuff in them.
    If you are comfortable taking it apart you could post a few pics of the timer and maybe that will bring up more conversation.
    Oct 2014
    Australia
    32
    Cheers. I wonder if it's possible to remove the face of the timer without too much drama? Has anybody done this?
