Results 1 to 7 of 7
Thread: Connecting Shop Vac to Skimmer - How?
    Jun 2010
    Toronto, ON. Canada
    230
    I understand from a few friends and the local pool store that I can close my own pool here using a shop vac.
    How does one connect the shop vac to the 1.5" skimmer connection?
    Thanks!!
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: Connecting Shop Vac to Skimmer - How?
    Quote Originally Posted by Shaf77 View Post
    How does one connect the shop vac to the 1.5" skimmer connection?Thanks!!
    First picture, Post # 2 - Is what you are looking for.
    Modified Cover for Hayward Super Pump for Closing Swimming Pool
    Post # 1 (SP-1023) is the part #. This is for the 1.5". If your shop vacuum is bigger, then you will need an adapter. This place has everything you need. If you e-mail them, they will get back to you very quickly, even on Weekends. Explain to them that you wish to have an extension form your skimmer to a 2" hose, if that is the size. Otherwise, the hose that was purchased is in the first post fits the 1.5".
    BTW, just came back from Woodbridge-Vaughn, ON this past week. Nice place. The specialty food stores in Woodbridge are really nice.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by Catanzaro View Post
    Thanks!
    I need it for tomorrow as I want to close the pool before our Thanksgiving long weekend.
    My shop vac would have a 1 7/8" hose.. How do I reduce that to 1.5"?
    Also - the part that you suggested (SP-1023) - I have a couple of those lying around. Tried threading one into the skimmer, but doesn't seem like the threads match. Weird, will try again later today.
    Yes - Vaughan is a nice area.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    My vacuum has a cone shaped nozzle for use as a blower. I put a couple of wraps of duck tape around the cone and it wedges into a pipe. I find it much easier to blow the skimmer line out from the pump end since the spray ends up on the pool deck instead of all over the equipment.
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by JohnT View Post
    I'm planning on blowing through the skimmer. Is that better or not? That's how the last the Pool Stores have closed my pool.
    Doing it myself for the first time.
    Catanzaro's Avatar
    Jul 2014
    2,255
    Chances are that is a 2". Take the hose you have, in addition to the part that is threaded to the skimmer to Lowes or Home Depot and your will find the fittings to reduce 2" to 1.5". If not, you will have to order items on line. Maybe a plumbing store as well.
    The fitting maybe for an above ground pool or for a return jet, not sure. Was it loose? Or just did not thread right? Do not jam anything in the skimmer. You kind of have to figure out how to adapt your hose to your skimmer. As you can see in my post, I created a modified cover at the pump housing, not through the skimmer. You may be able to push air at somewhere else, near the equipment pad. Maybe posting a few pictures of plumbing, pump, etc. maybe helpful and we can figure something else out.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Ditto. I drain below skimmer, and blow it out from the pad.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
