Thread: Hi from EndlessScott in Canada
    Oct 2015
    Alberta, Canada
    5
    Smile Hi from EndlessScott in Canada
    Thank you all for the educational forum and the sincere help you all respond with for members with troubles.
    I have just completed the below pool for the wife (I got a lift in the garage)
    Now I realize what she really was doing - I get to do the maintenance also!
    Thankfully I hope to keep things pretty easy and trouble free with the suggestions from everyone here.
    Off to do some more reading...
    Thanks all,
    Scott
    Indoor above ground 7'x17'x52" Endless Pool 3800gal
    Vinyl Liner on Galvanized Panels, Swim Current Generator, Spa Jets, lights
    Bleach and UV sanitizer needed 30ppm CYA. Cartridge filter
    Full roller cover, 250cfm Heat Recovery Ventilator, RH stays below 52%
    Jun 2014
    15,255
    Re: Hi from EndlessScott in Canada
    Hello Scott, and welcome to TFP!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    The only hard part for you is going to be getting the necessary test kit. If you know some friends in the states, you would do well to touch base with them. After that, the rest is pretty easy!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
