Page 1 of 3 123 LastLast
Results 1 to 20 of 58
Thread: Pentair single speed 1 HP pump ?
    Sep 2015
    Bradenton
    71
    Hi Guys,
    I understand that their can be some cost savings with a Variable Speed pump.
    Is it worth making the investment in a new Variable Speed pump - if so, what brand and model makes best sense ?
    Thank you!
    8,000 gallon, IG (in ground), Gunite, Pleated Cartridge (Brand ?), Pentair 1 HP (Single Speed), Built in 2006, No SWG (yet), Location: Tampa Bay, FL
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Pentair single speed 1 HP pump ?
    It really depends on your electric cost. But in the end I think most would say, yes. Some folks get a quicker return on the investment if their electric is high. Mine is only .10 per kilo so it would take quite a while to pay for itself. Somebody paying .40 per kilo would get there 4 times faster.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Sep 2015
    Bradenton
    71
    Quote Originally Posted by pabeader View Post
    Thanks pal! What make and model(s) are most recommended ?
    Jul 2015
    Central Valley CA
    1,109
    Quickest return on your money at most any electrical rate is a 2 speed usually pays for its self in a year or two. VS usually take several years but the pool geek factor on a VS pump is priceless. Check your local power provider, many offer some sort of rebate to upgrade may make the decision easier to see what qualifies for a rebate should they have one.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Another option would be to just replace your current motor with two speed motor. It is cheaper, requires no plumbing changes and will likely have a lower lifetime cost than a VS pump given your energy costs.
    Mark
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    What size is your plumbing? 1.5" or 2"? Any water features?
    Isolated Spa - 345 Gallons
    Sep 2015
    Bradenton
    71
    Quote Originally Posted by JVTrain View Post
    It looks like 2'' but not for sure certain.
    No water features.
    What is the expected lifetime of a 2-speed pump, versus a multiple-speed pump, versus a single-speed pump ?
    mas985's Avatar
    Pleasanton, CA
    11,741
    I have not seen any significant evidence to suggest the lifetime is longer or short for any type of pump motor.
    Probably one of the most common failures of motors is that the pool owner fails to detect when the shaft seal has failed which then rusts the motor bearings. Not really a failure of the motor though.
    Another common failure with standard motors (1 & 2 speeds) is a failed capacitor. But those are really easy to replace and fairly cheap.
    As for VS motors, besides bearing failure, the drive can fail and are very susceptible to power surges so if you go this route, make sure you install surge protection for the drive. On this forum, a failed drive is almost always due to lack of surge protection. I don't think I have seen a failed drive with surge protection. At least not yet.
    Mark
    Sep 2015
    Bradenton
    71
    Quote Originally Posted by mas985 View Post
    What is the cost of a two speed motor versus a single speed motor (1 HP) ?
    What brand do you recommend ? Have a link to product ?
    mas985's Avatar
    Pleasanton, CA
    11,741
    What is your current pump model#? How old is the pump?
    Mark
    Sep 2015
    Bradenton
    71
    It's a Pentair Superflo High Performance Pump (1 HP single speed)
    It was installed with the pool in 2006.
    mas985's Avatar
    Pleasanton, CA
    11,741
    A.O. Smith: B2980 (230v) or a B2981 (115v) depending on the current voltage wiring. They also have versions come with timers (B2980T/B2981T) if you want that.
    Just google the motor numbers to find places to buy them.
    Mark
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    you mentioned surge protection...I wonder if having a GFCI breaker would serve as adequate protection for a vs motor if thats what the poster has.
    Dolphin E10 Cleaning Robot.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Unfortunately, GFCI and surge protection are twp different beasts. GFCI detects a differential in current entering and leaving a circuit. Surge protection, blocks voltage spikes.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    good to know. I'm considering a vs and had not remembered the surge protection addition.
    Feb 2014
    Central Minnesota
    5,080
    This is likely the exact replacement motor I'll be going for when I replace my dry end, maybe next spring. This B2980 I believe is a 3/4 HP, I may go with a B2982 @ 1 HP. Not sure yet.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Superflo is an up rated pump so the 3/4 HP full rated motor is large enough for a 1 HP Superflo pump.
    Mark
    Feb 2014
    Central Minnesota
    5,080
    Good to know. Looking for some savings on the electric bill and that's even better when comparing the B2980 versus the B2982.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Energy use will be about the same between an over sized motor or a "right" sized motor. It is mostly the impeller that determines energy use (motor efficiency too). Motor label ratings are for full load but an impeller is much less than full load on an over sized motor.
    Mark
  20. Back To Top    #20
    Sep 2015
    Bradenton
    71
    Thanks guys.
    Where is the best place to buy these motors?
    Thank you.
    Will I need to add surge protection when installing the new motor?
