Thread: pH and TA too high
    Oct 2015
    LaGrange Georgia
    1
    pH and TA too high
    Having trouble getting my pool's alkalinity and pH down. I know I'm supposed to get alkalinity down to acceptable level before dealing with pH, but how do I do this? I'm assuming I use pH lowering chemicals?
    20,000 IG vinyl hayward sand pro series filter vari-flo valve sta-rite P2RA centrifugal pump with trap rheem heater Hayward chlorinator spa ? type silencer bubbler with waterfall pentair valves polaris PB4-60 booster pump polaris 280
    30,415
    Re: pH and TA too high
    Welcome to the forum.
    1. What are the levels you are talking about?
    2. Why do you think TA must be dealt with first?
    3. Have you read "The ABC's of Pool Water Chemistry" up in Pool School?
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    One way to lower your TA is to lower your PH. Please use Pool Math to determine how much MA (Muriatic Acid) you will need. Also, do you have one of the recommended test kits? This will ensure accurate testing as you go along. How do you know your TA and PH is high? How are you testing now?
    We recommend highly using muriatic acid, which can be purchased at most paint stores. Eye goggles, a sweatshirt and gloves are recommended if you are not used to working with MA. Also, please purchase a measuring container in the paint section (1 gallon is fine) as you will need to measure MA accordingly. BTW, the measuring container works great for bleach (liquid chlorine) as well.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
