Thread: Using Chlorine generator with Bromine
    Mar 2015
    Stanwood, WA
    4
    Is it possible to use a Chlorine generator and saltwater as the oxider to activate the sodium bromide? I am using the 3 step process now with the bromide tablets and MPS for weekly shock. Could I use saltwater and the Chlorine generator instead of the bromide tablets?
    Thanks!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Using Chlorine generator with Bromine
    Welcome to TFP!
    Yes that is possible, and it is also possible to add enough sodium bromide, instead of sodium chloride, to have the generator generate bromine directly. Note that not all spas use high quality components that can handle higher salt levels well.
    Mar 2015
    Stanwood, WA
    4
    Quote Originally Posted by chem geek View Post
    Welcome to TFP!
    I'm sorry to respond so late. Was expecting email subscription remainders. Anyway - would the level of sodium bromide have to be the same as sodium chloride, 2500-3000 ppm? And no way to test the sodium bromide level? Hmmm.... interesting thought, although I am finding it not too hard, nor expensive to keep the bromide tablets going.
    Mar 2007
    San Rafael, CA USA
    12,082
    You should check with your generator manufacturer to make sure their system is compatible with generating bromine, primarily in terms of its lifespan. As for the bromide salt level, the Genesis system uses around 1500-1900 ppm sodium bromide.
