Thread: Jandy Aqualinks How to Hook up Solar
    Oct 2015
    Phoenix
    15
    Trying to hook up solar to aqualinks. Is it a special sensor compared to regular temp sensor?
    Sep 2013
    Charleston, SC
    540
    Re: Jandy Aqualinks How to Hook up Solar
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Oct 2015
    Phoenix
    15
    Figured it out on a dual system board it's s-7 switch on board.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    And Yes, you use the same temp sensor (same part #).
    Factory Warranty Station for:
    Oct 2015
    Cocoa beach fl
    6
    Yea they're both 10k sensors. Put the water temp sensor after the filter and the roof sensor on the same roof as the collectors in a good sunny area which will not be shaded. Zip tie you're terminals so they won't pull apart and goop them with liquid tape because the sun will degrade the wire quickly.
