Thread: Need help for dual suction lines
    Oct 2015
    Phoenix /Arizona
    2
    it is historical that the pump size is to small up grade to better pump . Look at the amout of gallons / hour 1500 to 2500 will work on a 22' size x 52 above ground poolthe sell krystal clear 2500 cartridge filters with time for around 100.00. Can you help me I need the part number for the t piece. I want to run 2 pump Please Richard
    Oct 2015
    Phoenix /Arizona
    2
    Re: Question about Dual Suction Lines
    I need 2 t adapters for 1.5 " lines with screw on nut that screws to in or out or the plunger valves just the part numbers please trying to get info with out a part # is difficult
    Sep 2013
    Charleston, SC
    537
    Re: Need help for dual suction lines
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by rsolly55 View Post
    For just a little bit more money, you could switch to the sand filter. I got one for my 18' a few years ago at the end of the season, and it was sufficient enough to use when I upgraded to a larger pool. It keeps the water much clearer, and I only have to backwash occasionally, versus rinsing out/changing filters all the time.
    http://www.poolsupplyunlimited.com/I...FUKRHwod5wgDRQ
