Results 1 to 19 of 19
Thread: OK, so what is this stuff?
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    We don't close for the winter.
    About a month and half ago I did the whole Ascorbic acid treatment thing.
    Brought my chlorine levels back up.
    Brought my salt levels back up (water was about 62F at the time.
    When the water temp hit 65 I turned on my SWG.
    Water seems balanced, but I have these appearing all around the pool, just under the water line.
    General picture
    Here is closer look.
    30,000 Gallons, Hayward C5030 cartridge filter, IG, Plaster, SWG
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: OK, so what is this stuff?
    Off hand, I'd have to say either small gravel or tadpoles. (that's the best I can tell from the pics) -- It looks WAY too large to be black algae, if that's what you were worried about
    Luv& Luk
    -Ted
    30,419
    As always, a full set of test results helps us determine any water imbalance. That's the place to start.
    Another question, do the black things brush off easily or are they stuck on?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    In the top pic....are we looking down from the top at the water line? On the brown tile in between the grout lines it looks like greenish algae. Those other things...how odd....
    I agree, are you brushing the sides? Do they brush off?
    Please post your full set of test results.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Looks like caviar to me.
    11,969
    I was thinking kitty litter. but that wouldn't make any sense would it?
    rogerbrks's Avatar
    Round Rock, TX
    172
    If you had a hard rain recently, like this past weekend. It could be the gravel from your shingles on you roof. Not sure if your patio flooded and water got into your pool.
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    rogerbrks's Avatar
    Round Rock, TX
    172
    Are there any tall trees close by. My neighbor has a large oak tree and some other tall "trash" tree that dumps crud into my pool.
    Feb 2008
    Denton, TX
    5,061
    What sort of trees do you have next to your pool? Looks like the berries off of a wax myrtle.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by rogerbrks
    Well, same here....and we had several weeks of stuff that looked like coffee grounds! The color in OP's pic looks kinda' dark blue/dark grey/black on my puter, but the stuff in my pool was kinda' dark brown. It wanted to 'stick'.
    Had to do a bit of brushing/filtering/backwashing to get rid of it.
    I will admit; however, that the pool had less attention for the past 3 months than normal.
    You're done SLAMing when:
    11,969
    Quote Originally Posted by Butterfly
    Shame on the MOD....
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by frustratedpoolmom
    Yea, but it couldn't be helped! Family comes first!
    The good thing is that when you know how to take care of a pool (like what you learn from TFP!), when something like this happens, it is not very difficult to take care of the problem. My pool is beautiful and sparkling now! 8)
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    I'll try to get an analysis of the water done this weekend.
    This is looking down the wall. These have started appearing just within the first foot of the water line. Pretty much all around the pool, skipping some spots for whatever reason. I just took a shot of one spot where they are more densely populated.
    The brown stone is the coping/waterline stone. The black bits (about the size of kitty litter granules) are on the vertical wall.
    They are a little slimy, and do come off, but leave a black spot behind.
    But they are not super easy to know off.
    They are not from my trees, and the pool is over 30 feet from the house.
    Some have little air bubbles surrounding them.
    11,969
    Quote Originally Posted by fofa
    Well that is bizarre.....
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    99% sure that's frog eggs from the description. Do you get a lot of frogs in the skimmers?
    Casey's Avatar
    SW PA
    10,444
    Millions of frogs!
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    no frogs that I have seen. I have seen frog eggs before, and they are usually attached in a tube looking thing. These are pretty much detached, and all around the pool just below the surface on the walls. This was just one spot.
    Due to weather I didn't get a complete water analysis this weekend, but did work my plastic pool brush and got most of this off. It took a little scrubbing to get them removed, not a quick brush over like dirt or dead green algae.
    Jun 2007
    North Carolina
    82
    I'm anxious to see what this turns out to be. Can you imagine if they WERE frog eggs?! I'd love to see when the tadpoles hatch! I think the OP should leave them alone just so we can have some entertainment if they are indeed frog eggs.
    27' ABG
    Sand Filter
