Thread: Jandy AquaPure 700 Codes 120/121
    May 2015
    Newberry, FL
    3
    I have the old Jandy AquaPure 700 Power Center and the new 3 port cylindrical salt cell. The Power center is saying Service with error code 120 (when in forward mode) and 121 (when in reverse mode). I found the troubleshooting guide but have been unable to diagnose the problem. Here are the details:
    1) Cell, PIB board and DC cord were all replaced, but am still getting the same codes. The only things not replaced are the front board, the transformer and the flow sensor.
    2) I measured the voltage at all of the test points and here they are:
    Cell: 36.3 VDC ***
    Back Board
    1-8: 80.3 VAC
    2-7: 71.3 VAC
    3-6: 21.1 VAC
    4-5: 94.8 mVDC ***
    Voltage coming into Transformer: 245 VAC
    Front Board
    AC: 20.8 VAC
    HK: 89 mVDC ***
    Salinty/R-Temp/KeyC: 2.5 gpl ***
    Salinty/R-Temp/KeyD: 74 F
    H-Temp/KeyC/KeyA: 90 F
    I put *** next to the readings that seem to be out of spec. Also, the cell seems to be still generating chlorine as the level of chlorine in the pool is fine. Does anyone know what the issue might be?
    Dan
    Jun 2011
    Long Beach, CA
    2,781
    Re: Jandy AquaPure 700 Codes 120/121
    Is the PIB board correctly configured for a 700 sized cell. The default is configured for a 1400 sized cell. Make sure the cell is clean and how old is it?
    May 2015
    Newberry, FL
    3
    Hi Ping,
    The cell is only 8 months old. How do you configure PIB for 700 size cell? Is there a jumper?
    Dan
    Jun 2011
    Long Beach, CA
    2,781
    Yes, you need to make sure the jumper is cut. See this workbook, http://www.nuccibros.com/sec_0934drR...20Workbook.pdf.
    Thit workbook will have all of your troubleshooting solutions.
