Thread: Jandy LED lights
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Jandy LED lights
    Wrapping up my third season and my 6th Jandy LED light has gone bad. Same thing happens every time, the seal fails and water gets into them. Jandy said that the installers could be over tightening them and braking the seals but the last 2 were verified that they weren't over tightened when installed and they failed the same way.
    Any one else having problems with these lights failing?
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    Mar 2017
    Cedar Creek, TX
    4
    Re: Jandy LED lights
    What were your symptons when the light was failing? Mine might be having issues.
    What brand of light do you use now?
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Lights would just quit working completely after a couple hours of flickering and changing colors. Jandy bought the SAVI light brand and replaced all of mine with those under warranty. No problems now.
