New PB evaluation in Prosper Texas
Sep 20, 2015
2
Prosper tx
Hi All,
I'm located in prosper, TX, just north of Dallas and we are on the evaluation process with the local PB's getting the numbers/quotes and ideas and wanted to share some info about the first PB numbers that we got from last week.
This will be our first pool and we have so many questions and concerns, please check the list with the Pool/spa specs with the equipment and let me know your comments or recommendations specially on the equipment, the first impression that I have is that the PB is trying to add a lot of equipment and I just want to make sure that’s necessary to have 2 pumps, etc.. ….
any comments ideas or recommendations are welcome....
Pool
Pool Sq. Ft……… 539
Perimeter………… 99'
Pool Size………… 38' X 17'
Gallons…………… 20,162
Coping……………………… Oklahoma Flags
Jets………Yes
Overflow Drain………… Yes
Tile…………………………… Standard 6"
VGB Safety Drains…… 4
Skimmers………………… 2
Returns…………………… 5
Sheer Descents………… 3
Int. Finish………………… Satin Matrix (Wet edge)
Spa
Spa Sq. Ft………… 47
Perimeter………… 27'
Spa Size…………… 9' X 6'
Gallons…………… 969
Hydro Therapy Jets……6
Fountain……………………1
Raised……………………… 12"
Spillway…………………… Yes
Veneer………………………Oklahoma Chop VGB
Safety Drains…… 2
Equipment
Filter……… Jandy 60SqFt DE
Controller Jandy iAqualink PS-6
Heater…… Jandy JXi 400K BTU NG
Cleaner…… Polaris 280 Black Max
Oxidizer… DEL Eclipse 20 15-50k gal
Blower…… Polaris 2.0 HP Blower
Pump……… Jandy VS+SVRS 2.0HP
Cir. Pump………… Jandy VS+SVRS 2.0HP
Sanitation…………RB320
Gas Line by……… PB
Cleaning Pump… Polaris 3/4hp Pump
Pool Lights……… 2-Jandy LED Nicheless
Spa Lights…...……1-Jandy LED Nicheless
Structure
Steel………………………… #3 on 8" centers
Gunite……………………… 3500 psi
Alternate Bars……………Yes, in Floor
# of Benches…………… 6 inear Ft…………………… 23'
Tanning Ledge………… 1 Sq Ft………………………… 27
Reverse Beam……………Per Plan
Raised Beam…………… Yes
Decking
New Decking…………… Rock & Keyston Color……… TBD Sqft… 588
Sqft… N/A Linear Ft of Turndown……… 15
Expansion Joints………. Expansion Joints Saw cut
Mastic Color…. Tan
Autofill/Overflow………. Yes
Additional Options
Sod Repair…………………Yes, [4 Pallets, $475 ea
Sprinkler……………………Yes (3 zones. 550 ea add.)
Temp Sprink…… Yes
Pool Maint……… 1 Year
Brass Upgrade… Yes
Fence Repair…… Yes
New Fence……. No
Price …..65,480
Thank's
toton
Welcome to TFP!
The first comment i have is that the pool builder is doing you no favors with a couple of the items he is suggesting.
The DEL Eclipse is an ozone generator. There is no need for ozone in an outdoor residential pool.
The RB320 is a tricolor puck erosion chlorine feeder. We find that use of these types of equipment for primary chlorination leads to over stabilization (about half of a tricolor puck is stabilizer), which leads,to more problems down the road. We believe the primary source of chlorine should be non stabilized - either a salt water chlorine generator or a liquid chlorine injection system.
I recommend a visit to our Pool School (link at the top of every page). Start with the Pool School - ABCs of Pool Water Chemistry to understand this a little more.
