Results 1 to 11 of 11
Thread: Siphoning rain water off the pool
    Oct 2015
    Inman, SC
    2
    Question Siphoning rain water off the pool
    When siphoning water off the pool cover after a heavy rain, it seems to just lower the water level, not bring the cover back up to the top - is this normal? Pool covers must not be waterproof, and I am wasting water that in the spring I will have to refill - is there a way to siphon without losing the water level?
    24 foot AG pool
    20 + years old, vinyl lining, fiberglass shell
    Hayward pump, sand filter
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Siphoning rain water off the pool
    Hi, it depends on the cover. Some are mesh, yours must have holes somepace. My last one was solid and did not leak first 2 years, but windstorm ripped it on top rails. I just bought a new solid one so I hope it does not have holes.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Quote Originally Posted by Skiclubber View Post
    If I am reading your post correctly, this is simple. Your cover has slack in it. As water lays on top of the cover, the weight pushes the cover down, eventually pushing water up in the pool. When you remove the water off the cover, the level below the cover will go back down to normal (assuming you do not have rips in cover). If you have rips in the cover, then you will continue to siphon the bottom water. Pull the cover tight on all ends in the spring above water line and keep siphoning the water as this will prevent you taking too much out of the pool is there are tears.
    I thought the same thing. Came back from a 4 day trip and the skimmers were full of water. As I siphoned the water off the cover (not 100%, but a lot), the water drained out of the skimmers, near the doors.
    I thought to myself "How could water have seeped through the cover. It was like we had 15" of rainfall. Was close to 8 inches".
    There is still some water left, which will be vacuumed before the next freeze. I have a thin regular cover with water bags.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2012
    Blaine, MN
    106
    I ran into this problem last year. I think the key might be placing a pool pillow or something similar underneath the cover to help lift the cover up. The cover worked great last fall but because of snow weight, I released the cover so it wasn't taut and then water collected on the top. I tried siphoning it off but ran into the same problem as you. I ended up just taking the cover off because it was a never-ending siphon job. This year we will try putting the weights back on make the cover taut. Hopefully with the pillows underneath it will help to make the cover taut and can get the water to run through the mesh
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Catanzaro's Avatar
    Jul 2014
    2,256
    Placing a few pillows in the middle may work. This will raise the tarp and have water drain off the cover. You only need a 1/4" pitch at most. If the cover is tight, rain will just wash away, although snow may bring the tarp back down. If you have a good back-pack blower to remove snow, this works well. I use my Red Maxx for clearing snow off landscaping, cars, drying vehicles, and the list goes on. Good luck and take care!
    Oct 2015
    Inman, SC
    2
    Quote Originally Posted by banditig View Post
    Thank you for your reply. My cover is similar to tarp fabric - I don't see any holes, but am not sure there aren't any. I assumed all pool covers for above ground pools were made of the same material.
    Thank you for your reply. The cover is not pulled tight, but does sit on top of the water. I will try to tighten the cover up and get the slack out of it when it it time to open it again next year.
    Thank you for your reply. There is a big pillow in the middle of the pool making a moat around it. At least a good bit of the water is off the cover which has to be better for the pool as that extra weight is not straining against the sides. I like the idea of weights - can no one design a cover that you just slip over the pool and it stays tight even when the rain falls????
    Thank you for your reply ... no snow to worry about (unlikely) here in SC, and I think based on what I have read from other folks that I may try to tighten the cover and use some weights. If I can get rid of that moat - all would be well.
    24 foot AG pool
    May 2012
    Montville NJ
    545
    I am in the same boat as you. The covers work great the first year - they do not leak. After that, they ooze water through them. I can syphon all day and it sucks water right through the cover. One trick that sort of helps, is to put your pump in an upside down Frisbee. It helps stop the pump from sucking water right through the cover. If using a syphon hose, put the end of the syphon on the Frisbee.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jul 2014
    Hope Mills, NC
    567
    After the second year, my cover developed the planetarium syndrome. Lift it up and get underneath it, look up and the pinholes look like stars!
    They are mostly junk and disposable, but that's not what the manufacturers say!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    I agree with Griswald, I buy the cheapest cover and dispose of it in the spring.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    May 2012
    Montville NJ
    545
    If I was going to go the throw the cover out in the spring route, it would be cheaper to buy a large tarp than a supposed "pool cover"
    -dave
    Zodiac Wahoo
    Jul 2015
    Kentucky
    1,126
    I too buy the cheap covers, as I've found the expensive ones don't last much longer anyway, and they cost a lot more to replace, so cheap it is .
    I use clothes pins to tighten up my cover on my AGP. After the cover is on, I go all the way around it pulling it tight, and placing a clothes pin about every 6-12" and clip them under the lip of the pool frame. It works great, and is an inexpensive fix because I can never get the wires that come with those covers tight enough, regardless of what I do, so luckily, the clothes pins have solved my pool cover sagging issue. I hope this helps, and have a wonderful day.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
