Results 1 to 9 of 9
Thread: Pentair UltraFlow Head curve
    Apr 2009
    Toronto, Canada
    33
    Does anyone have head curve for older UltraFlow Pumps ?
    Trying to get exact GPM. I have 2 Pentair UltraFlow pumps:
    1) 1 HP 1.25 SF
    2) 1.5 HP 1.1 SF
    Total head is in 55 ft. range. I am getting wide range of results for different pumps with the same HP (obviously, because the pumping mechanisms are different).
    Igor.
    16K gallons Vinyl Inground with spill-over spa. 1.5 hp Pentair UltraFlow, 26" Pentair Meteor sand filter, Raypak Gas heater.
    Re: Pentair UltraFlow Head curve
    I believe that this UltraFlow manual has the curves you are looking for.
    Apr 2009
    Toronto, Canada
    33
    Thanks !
    I did see this before but do not see 1.25 and 1.65 BHP pumps.
    The pumps are shown in the manual based on their advertised HP, which won't be the same as their brake HP. What are the listed HP and service factors (SF) on the two pumps you are trying to look up?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by iskubits
    1) 1 HP 1.25 SF
    2) 1.5 HP 1.1 SF
    Those should be labled as uprated pumps but there are two flavors, UF & UR. However, head loss will be dependent on the pump HP, SF and model. How did you come to 55 ft. of head? If you don't have direct measurements, you are probably better off using standard plumbing curves.
    Mark
    Apr 2009
    Toronto, Canada
    33
    Gage shows 15 PSI (* 2.31 + 75% of it comes to 52.55 Ft of head so I rounded it up to 55). This is on a larger pump.
    As per my original post pumps are 1.5 HP with SF of 1.1 and 1 HP with SF of 1.25. BHP of 1.65 and 1.25. None of the curves are for these models.
    Igor.
    Maybe I am missing something obvious again, but how do you know that none of those curves are for the model you have? Pentair doesn't list the brake HP, just the full rated vs up rated distinction. The SF numbers you listed sound like standard up rated motors, which I would imagine match one of the two possible (UF or UR versions) up rated pumps of the corresponding HP (1 or 1.5) in that manual.
    Apr 2009
    Toronto, Canada
    33
    Jason,
    You are right, those are not BHP. I got confused.
    Thanks for your help.
    Best regards,
    Igor.
    Apr 2009
    Toronto, Canada
    33
    Sorry - one more question.
    Am I correct assuming Sand Filter adds around 25 ft of head (10 filter and 15 backwash valve) ? It is 26" Pentair Meteor.
    Thanks.
