Thread: Sta Rite SR333Na malfuction
    Oct 2015
    Wallace, N C
    2
    My Sta Rite SR333 has been unused for some time. When I attempted to heat the pool it work well for a while then started firing the burner and shutting down. Thinking it was the regulator I replaced it with and identical regulator and the problem was not fixed.
    I believe based on research that the ignitor could be bad even though the heater is firing.
    My question is does the ignitor just light the Lp or does it light and have other jobs to maintain the flame?
    Indoor, in ground, freshwater pool. Cement with plaster finish. Retangular 12 X 24. 3.5' deep to 6'. Approx volume of water 8400 US gallons. Returns 3- 1 1/2". Suction 2 bottom suction 1 1/2" - 1 vacuum suction 1 1/2". Skimmer 1 1/2". 3/4 Hp Hayward pump. Frog Cycler. Hayward filter system (Star Clear Plus). Heater Sta Rite SR333NA.
    Jun 2012
    western NY
    1,560
    Re: Sta Rite SR333Na malfuction
    There should be some diagnostic codes to give you an idea what might be wrong...at least a starting point. It looks like the igniter may also be the flame sensor on this unit. I also see stack temp sensors on the schematic. You really need to see if there is any indicator lights giving you a code.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Is the "service heater" LED coming on? If so, you need to look under the round dome top to see what LEDs are lit on the board. This is if the display is not giving you a code that beings with E.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Oct 2015
    Wallace, N C
    2
    No error codes on display. AGS light is on in circuit board. Removed and replace AGS. Same issue. Found the ignition module should read a resistance of 50-500 ohm. My reading is 0. Ordered ignition. PentairPools was helpful to do test. Thanks for replies. Hope to have part Monday.
