Results 1 to 7 of 7
Thread: Just for Clarification
    Aug 2015
    Norman, Ok
    7
    Using the Taylor 2106 FAS-DPD test kit on the reading I get for FC should it be multiplied by 2.25 to achieve the Bromine reading for sanitation???
    Intex 210 gallon vinyl outside inflatable pool. Cartridge filter,3part Bromide,Taylor K-2006 (FAS-DPD) kit, held to 100 degrees. sitting on 3/4" foam padding on concrete and has a spa cover. Used Daily with 2 people an hour a session, new on 8-22-15 first fill
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Just for Clarification
    Hi, sorry don't know answer to your question, but I'm looking to purchase one like that. Can you use in very cold weather? Or at least somewhat cold. How do you like it?
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, you multiply the FC result by 2.25 to get Total Bromine.
    Aug 2015
    Norman, Ok
    7
    Thanks again Chemgeek. I had read that but there were times that it is written in a way that left some doubt.
    Aug 2015
    Norman, Ok
    7
    Quote Originally Posted by banditig View Post
    There is a post that talks of this but this will be my first fall/winter with the inflatable vinyl spa.Mine is outside on the uncovered Patio and it sits on the supplied bubble mat plus I bought the expandable lock together exercise mats from SAMs club (2 packets) for insulation and to create a nice floor. Currently our Temperatures are dropping to 52 at night and it is fine but when it starts hitting a long string of mid 40's I think I will take it down. As to if I like it? The main reason to purchase was to test if a spa was something my wife and I would like. The purchase and set up total with the Taylor test kit, chemicals, cup holders, exercise mats etc... Was at $400. A real bargain when compared to used or new full size spas. This allows us to try one as well as learn proper care before/if we jump in whole hog, so to speak. In my opinion, it's a fantastic economical way to get exposure to a spa. Sure it does not give you all the bells and whistle the main ones do but it does expose you to one. Whatever you decide good luck.
    Do you have the Taylor K-2006 or the K-2106?
    The Taylor K-2106 is designed for bromine. If you use a 10 ml sample, you multiply the number of drops by 1.25 to get the total bromine. If you use a 25 ml sample, you multiply the number of drops by 0.5 to get the total bromine.
    Total Bromine Test
    1. Rinse and fill large comparator tube to desired mark with water to be tested.
    NOTE: For 1 drop = 0.5 ppm, use 25 mL sample.
    For 1 drop = 1.25 ppm, use 10 mL sample.
    2. Add 2 dippers R-0870. Swirl until dissolved. If total bromine is present, sample will turn pink.
    NOTE: If pink color disappears, add R-0870 until color turns pink.
    3. Add R-0872 dropwise, swirling and counting after each drop, until color changes from pink to
    colorless.
    4. Multiply drops in Step 3 by drop equivalence (Step 1). Record as parts per million (ppm) total bromine.
    Instructions for the K-2106.
    Edit- The k-2106 and the k-2006 are probably the same test kit other than the instructions and that the 2106 doesn't have r-003 to test for combined. R-0871 and R-0872 are probably the same reagent. The result comes out almost exactly the same if you multiply 0.5 x 2.25 = 1.125 or count each drop as 1.25.
    Support the site
    Aug 2015
    Norman, Ok
    7
    Thanks James, I will note the differences on sample size. It's making sense now. I really appreciate chemgeek and people like you taking the time for answers
