Thread: Need Help With Cover- Unique Pool Application with photo
    Apr 2014
    Long Island, NY
    20
    OK, so I need to purchase a winter cover for my 24' radiant pool. As you can see in the photo I recently had a block wall installed around the pool with stone coping. The measurement from the outter edge of the coping to the other edge measures 26'. I typically lower the water level in my pool below the return so thats about 17" below the top edge of my coping. Any suggestions on what size cover and best way to secure it.
    Sep 2013
    Charleston, SC
    540
    Re: Need Help With Cover- Unique Pool Application with photo
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    That's a tricky one somewhat. I personally would buy a much larger cover that would be large enough to go all the way to the ground where you have a flat surface. Then use water bags or water jugs to hold the cover into place.
