Results 1 to 9 of 9
Thread: 2 vs 3 returns
    Aug 2015
    Massillon /Ohio
    5
    2 vs 3 returns
    Hi,
    We had a new IG pool installed in May 2015. This was our first pool ever ... it's an L shaped 38x18x26. No main drain. As we were looking over our contract, we noticed it says our pool will have 2 Skimmers and 3 Returns. Well he installed 2 Skimmer and just 2 returns. Is that something we should be concerned about? Right now there is a return in the deep end and one in shallow end. I think the other one was to go near the steps in the "L" area. What are your thoughts? Big deal, not a big deal? Should we ask to be compensated for the missing return? He wants us to sign a form holding him harmless from anything ... should we sign it?
    Todd and Bernadette
    IG "L" shaped, 18x38x26, 32k gallons, salt water, Hayward IG Super Pump 1.5 hp, Hayward cartridge filter, Hayward 200L BTU heater, just built May/June 2015, use city water to fill
    Aug 2014
    NJ
    435
    Re: 2 vs 3 returns
    I don't have an opinion about the missing return, but what is it you are getting for signing the form? In other words why would you sign such a form? Are you recieving something in return?
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    JoyfulNoise's Avatar
    May 2015
    13,254
    2 vs 3 returns
    At this point it is too late to do anything about it as there is no reasonable way of adding a return.
    You should discuss this with your PB and see if there's some form of compensation. There's no way to know if you circulation will suffer or what impact this might have but missing the installation of a return is a pretty big screw up in the plumbing layout. I'm actually quit surprised no one noticed this??
    Matt
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: 2 vs 3 returns
    " He wants us to sign a form holding him harmless from anything ... should we sign it? "
    I would think he wants this as he knows he has not lived up to the terms of your contract?
    He owes you a return or some form of compensation
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Donldson's Avatar
    NW Ohio
    2,917
    Re: 2 vs 3 returns
    We are a pool care forum. You need to discuss this with a lawyer. You need to find out what all in your build contract has not been fulfilled and what you can do about it. Then you need to find out if there is any obligation on your part to sign anything the builder is asking you to sign and what ramifications there are if you do sign it.
    We can offer opinions but I am guessing few or none of us are licensed to practice law in Ohio. You need professional advice on this.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,258
    Re: 2 vs 3 returns
    Please do not sign any "hold harmless" agreement. Your contract is with the PB, which means the PB has to honor their contract. By you signing an agreement, you may be waiving any rights under the terms of the contract. We are a pool forum as mentioned previously, but I would contact an attorney. If you find out later that the extra return jet is causing issues with the pool, you could have recourse. You at the moment are in the drivers seat.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Aug 2015
    Massillon /Ohio
    5
    Re: 2 vs 3 returns
    Thanks everyone. Sorry if i implied i was looking for legal advice ... i wasn't. I just wanted opinions on whether the 2 vs 3 returns was a big deal and if it was normal for a PB to ask for someone to sign off on a pool build. Like i said, we have never had a pool before and right now, we do not necessarily trust our PB. I appreciate everyone's opinions ... and fully recognize it is not legal advice.
    May 2015
    13,254
    Re: 2 vs 3 returns
    The sign off itself isn't unusual, most PBs require that you sign off on each payment including the last one which essentially says that you accept the work and workmanship that has been done and you release the PB from any liability not covered under the warranty.
    What is unusual here is your circumstance (2 returns as opposed to 3) and that circumstance requires legal counsel and possibly some form of arbitration should you request compensation for the error.
    Matt
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: 2 vs 3 returns
    Post a pic of your pool with the skimmers and returns clearly labeled.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
