Thread: Winter Closing First Time. Aquador question...
    Jun 2015
    Pittsburgh, PA
    27
    Hello,
    This is my first year closing down my pool for winter. I purchased an Aquador seal for my skimmer. Am I correct that I do not have to drain any water from the pool if I use this? Or would it still be recommended that I still do drain below the return jet? We do get well below freezing up here in the winter usually...
    Also, should I simply bring the chlorine to shock level and be done with it, or would an algaecide also be recommended? And are there any other chemical level checks/adjustments I should be doing before winter, besides chlorine?
    Lastly, is there any during-Winter maintenance I should be doing after closing down? For instance, should I be periodically still checking chlorine levels during the winter, or can I just forget about it until Spring?
    Thanks in advance for the help! Everyone on this board has been fantastic so far with the help provided! We had a great summer!
    24' Round AGP, 4' deep, vinyl siding. 13,500 Gallons. Hayward Perflex DE Filter (EC40C75). Hayward Power-Flo Matrix Pump. TF-100 Test Kit
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Re: Winter Closing First Time. Aquador question...
    I'm just going to adress the Aquadoor question, more senior members can follow up.
    I have the Aquador and the Iluminator (return with light) and do not drain. I put on the door before taking off the hoses. The light comes out and I put in a big rubber plug. The door is hard to get on all the way. Make sure of a tight fit. You should not see any water outside in the skimmer afterwards.
    I use algecide, but you have to let your FC drift down to half of SLAM level before adding with pump running. Once closed I do not test until cover comes off. I do check under once in a while.
    Keeping water off the cover with 3/8 clear tube is all I do when not in freezing temps. If you keep the water off, leaves and debris will blow off.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jun 2014
    15,129
    jjherm7, in regards to your chemical questions .... once the water temp stays below 60, (yes) bring that FC up to SLAM level and let it mix for 24 hours and you are in good shape. Algaecide (Polyquat 60) "may" be used, but is not mandatory. In fact, many folks do just fine without it since the FC drops very little in cold water. As JoeSelf accurately notes, those who do chose to use Polyquat 60 must let the FC sink back down about hallway before adding to the water. Yes, you could check FC every couple weeks, maybe even once a month may be fine, to see if the FC is still holding well. No need to do much else unless your pool is uncovered and you need to scoop something out of the pool (i.e. dead critter or something). Hope this helps. Have a nice day.
    Pool School - Closing (Winterizing) Your Above Ground Pool
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Did you use one if these in the skimmer? Blowout Skimmer Guard - Winter Pool Closing Accessories for In-Ground Pools
    If so, and if you have no tile or anything that the freeze cycle could affect, and if you've blown out all the lines using Duck plugs, you don't have to drop the water level.
    Oops, just saw you're above ground. I can't confirm that the above is true in your case so disregard.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2014
    Northeast Alabama
    98
    When I close my AGP, I use a setup similar to what Swampwoman posted above, rather than an Aquadoor. I make sure the pool is clean, FC at SLAM level, install the guards (I don't lower the water level), disconnect the hoses, cover the pool, shrink wrap the edges, set the pool cover pump on top, put away equipment and done. In April when I open, it looks just like it did when I covered it in Oct. Couldn't be easier. Hope this helps.
    33 Round AGP, 26K gal, vinyl liner, 1 HP single speed pump, 1 Hayward wide mouth skimmer, Pentair sand filter, Taylor K-2006 test kit, Red Leopard Orbit suction auto vac, Pool School, TFTestkits, PoolMath, Support this Site!
