Thread: Pentair/Sta Rite Motor Manufacturer
    I hope that the world of TFP can help me.
    My pentair intelliflo failed, due to a leak through the seal plate, corroding the 'transfer case' (part that adapts from motor to seal plate) between motor and pump, and ultimately the bearing inside the motor. I've disassembled the entire thing, and need a source for the bearing and the 'transfer case' Thanks so much to Pentair who only sells the motor as an entire assembly, and will not disclose their vendor because it is proprietary. If it was so proprietary maybe they should remove the manufacturer label that gives the MPN as B7108I-41317 which corresponds to pentair part number 357294
    Does anyone know who makes these motors or where I can get replacement parts at a sub-motor level? Alternatively, anyone have a toasty motor that I could salvage parts from?
    Also, when I put this thing back together, any idea what I need to replace within the pump (seal plate??) to stop the leak out of the back of the impeller housing?
    Thanks so much!!!
    Sep 2015
    Cedar Rapids Iowa
    17
    Re: Pentair/Sta Rite Motor Manufacturer
    Maybe try an electric motor repair company to source parts. Particularly one that is a Pentair service center.
    25000 gallon in ground vinyl pool constructed in 1967 9 feet deep Oval. 1.5 hp Sta Rite Dura Glas 2 speed pump with Pentair Triton II TR60 sand filter and Pentair IC40 SWG. Non funtional Pentair Mini Max heater.
