Thread: Winter ?'s
    May 2015
    Central PA
    38
    Winter ?'s
    I added a skimmer closure and a plug for the return. Am I correct in not draining the pool to below the skimmer? Also, with the cover on, rain water is adding to the level below the cover....is that ok? Lastly, I have the skimmer gate closed so rainwater is collecting in the skimmer.....should the gate be open so it does not collect and freeze in the skimmer?
    ABG 24' Filter Cartridge 13,600 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Winter ?'s
    Hi, i don't close my pool or know how to close one. Here is a
    Here is an article from Pool School that should help. Pool School - Closing (Winterizing) Your Above Ground Pool
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    Re: Winter ?'s
    Hi pool.
    Do you have one of these gizmos? Blowout Skimmer Guard - Winter Pool Closing Accessories for In-Ground Pools
    They absorb the freeze shock to avoid damaging the skimmer when ice forms.
    If that's what you used, you should be fine. My pool is IG so my closing info might be different to yours though, so check around re best for AG. Eg. Those with inground and a tile line should drain below skimmer. Without tile line and with gizmo, and with single skimmer line, some techs don't drain IG's like mine.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
