Thread: Broken Sight Glass
    Oct 2015
    Shawnee/KS
    1
    Broken Sight Glass
    When winterizing the pool I broke the sight glass on the late model (3 years old) Hayward sand filter. Most of the exposed glass is shattered, but the threaded portion is in tact.
    Anyone have a way to remove the threaded portion?
    Thanks
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Broken Sight Glass
    Welcome to TFP!
    My first try would be with a heave set of garden gloves trying to west it out as is.
    If that didn't work I would use a very small screwdriver or scratch awl to break up the rest of it out of the threads.
    Safety first, before attempting any of this have anyone close wear safety glasses.
    Support the site
    Feb 2015
    Chandler AZ
    938
    Welcome to TFP!
    If you have a wine cork laying around, you may want to see if it will fit into the neck of the broken sight glass. As long as the cork sticks out far enough to grab with pliers - attempt to slowly unscrew the remnants. Or maybe careful use of needle-nose pliers to rotate it out.
    Whatever plan of attack you use, be extra careful to keep body parts away from the broken glass - and wear safety goggles too.
    I had a broken one several years back and was able to use needle nose pliers. As soon as it loosened up, it was easy to remove.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    May 2014
    Franklin, NC
    9,197
    P
    Quote Originally Posted by proavia View Post
    Welcome to TFP!
    I really like the cork idea!!!
    Plus, there are always corks available in my house.
    Support the site
    Find something that just fits inside the glass part and glue it in. Wait for the glue to set and then unscrew. Be careful not to get glue in the threads.
    Support the site
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,258
    I would recommend a set of "needle nose pliers" on each end. Possibly a second person helping. Grab firmly (wear gloves and eye protection) and at the same time gently turn counter-clockwise. This all depends if there is enough glass sticking out after the threads. Maybe applying some lubricant may help.
    One other option is to find something that could fit inside glass (maybe that could expand) on the end of a drill or a ratchet set. The whole concept is to grab and turn. Keep us posted!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
