Thread: Hayward« Aqua Rite PCB replacement issues
    Oct 2015
    Pasadena, TX
    I've replaced both pcb boards in my salt control panel and still don't get anything on the readouts and no lights are visible. It's like there is no power but I checked and there is power to the unit. Could the transformer be bad?
    In ground pool with spa
    iAqualink Salt system
    20,000 gallons
    Re: Hayward« Aqua Rite PCB replacement issues
    Google aquarite diagnostics manual.
    ps0303's Avatar
    Jul 2011
    Well did you check to see if you were getting power out of the transformer? If not, that's what you need to do next.
    A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you.
    chiefwej's Avatar
    Jun 2011
    Is there a fuse anywhere? Make sure that power is actually getting to the transformer. Then test to see if power is coming out of the transformer. After that it goes to the main PC board, which you say is new. If it weren't I'd be looking at the input resistor (thermistor).
    19k gallon Pebble Tec play pool/spa, Pentair Intelliflo VS (3 hp) 011018, Super II 2hp (for spa), Aqua Rite T-15 SWG, Pro Grid 60 DE filter, Hayward H400 & Heliocol Solar heating, A&A infloor system, fill water w/high CH and TA, 50 ppm borates,TF-100 test kit
