Results 1 to 11 of 11
Thread: New pool, first fill - from hot water tap?
    Oct 2015
    Austin, TX
    83
    Hi,
    This is my first post. I have learned a ton from the TFP website and I'm hoping to be a good contributor here in the future. I already have my TF-100 kit!
    We are getting close to completion on our new pool. We'd like to use the pool for a couple of weeks before it gets too cold. Daytime highs are still in the high 80's here in Austin, TX.
    We didn't specify a pool heater and I'm thinking about trying to get some heat into the water in the first fill. I don't have a pool heater but I do have a perfectly good regular 50-gallon tank-style domestic water heater rated at 36,000 BTU/hr (the same one that supplies the hot water to my house, of course!)
    I am thinking of filling the pool from the hot water tap. Of course I understand that after the first 50 gallons, the water will be barely warm - that same temperature you get when someone else took a shower before you and didn't leave you any hot water. But that's still warmer than the water coming out of the cold water tap, and that's good, right?
    I tried to do the math... if I have a 16,000 gallon pool, that's about 133,000 pounds of water.
    If I can get 500 gallons/hr from the hot water tap, I'll fill it in about 32 hours, so that will be 32*36,000 = 1,152,000 BTUs of heat into the water. 1,152,000BTUs/133,000lbs = 8.6 degrees, or maybe a little more than that if the hot water doesn't run that fast.
    So by my math, by filling from the hot water tap, I'd be able to increase the temperature of the pool for the first fill by a useful 8.6 degrees compared to filling from the cold water tap.
    My poolbuilder said he never heard of anyone trying this. Does anyone have any opinion? Tried it? Warned not to?
    Many thanks,
    Marc
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Jun 2014
    Roseville, CA
    343
    Re: New pool, first fill - from hot water tap?
    It won't hurt anything but your gas bill.
    Be sure to get a solar type cover, though. Most heat loss is at night, since the warmer water rises to the surface where the cold night air is.
    Give it a shot, and let us know how it goes.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    30,415
    Have at it but it won't work.
    Radiant and evaporative heat loss will probably cancel ALL of the heat gain. Additionally, you will have no hot water for your house
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    +1 to the solar cover, from what I have been reading here the cheap ones last pretty much as long as the expensive ones.
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    Oct 2015
    Austin, TX
    83
    Thank you all! Solar cover it is... starting to fill on Sunday if all goes well...
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Here's a question, "What is the temp of your cold water?" Your 8.6 rise will be from that. Also, your heater will be running the whole time you are filling. Are they even designed for that?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Marcgr
    Besides heat I think the solar cover is also helpful in keeping your chemicals a bit more stable and also keeping some leaves and dirt out.
    Solar Blanket, Well Water, Borax Added. 68
    Oct 2015
    Austin, TX
    83
    So, we filled it up yesterday, air temp in the 80's, water temp 76 straight out of the cold water tap, and we swam!
    Solar cover arrives Wednesday, hopefully we'll get a couple of weeks of swimming before it gets too cold...
    Thanks again all!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Wow! My cold water is like 50 degrees! No wonder you were thinking of using the water heater.
    Oct 2015
    Austin, TX
    83
    So, now I am discovering that my new solar cover is not compatible with my PV3 infloor The infloor directs water on top of the cover when it runs. I will have to figure out a fix for that...
    Nevertheless, my water is still 76 degrees, have been swimming in it every day!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Place the solar cover on during the evening and leave it on until the morning. Then after you remove the cover run the filter, etc. I plan on purchasing a cover next year and this is the only thing I can think of. If this PV3 is infloor, where does the water come from? What exactly is it?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
