Thread: GFCI on SWG is out...
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    We have had massive amounts of rain in my area...although it was badly needed there is too much of a good thing!! I noticed the other day that the GFCI on my SWG had gone out. I've tried resetting it, both from outside and in the main box in the basement, but neither way works. Whether it went out because rain somehow got into the box or because it just went bad (only after 2 years), I have no way of knowing. I'll be closing soon. Is there any reason that I can't wait to have the GFCI replaced in the spring and just chlorinate with bleach until closing? The pump still works...knock on wood...it is on a separate breaker...
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: GFCI on SWG is out...
    Absolutely fine to use liquid chlorine in the mean time. Many folks use it exclusively all the time.
    Jul 2014
    Hickory, NC
    154
    Thanks, that's what I thought since I've read that on here a lot...I just don't like the idea of carrying all that bleach around or I would consider that as well. Just wanted someone else to verify....thanks!
    Sent using Tapatalk
    ~ TF-100 test kit
