Results 1 to 7 of 7
Thread: Floating pool liner magically disappears
    Aug 2015
    Spartanburg, SC
    39
    New pool owner here. I live in South Carolina. The rain here has been ridiculous not only for the past week but especially this weekend with the hurricane off of the coast. I went outside this morning to find my pool liner beginning to float in certain sections away from the wall of the pool. This was right around the time that my main pump was scheduled to turn on. I went back outside about an hour ago and the vinyl liner is now back to normal pretty much. There are a few areas where it has come out of the track at the top a bit but hopefully I can repair those after all of this rain. My question is...... does this mean that the previous owner must have had some sort of system installed that diverts the groundwater away from the pool when the main pump is on and the ground has become saturated? I'm assuming it has to have something to do with the main pump being on because the rain is ongoing and won't be stopping for the next couple of days. If this is the case, then I'll let it run 24/7 until a few days after the rain is gone.
    Thanks to anyone who can help.
    18K gal free form, IG vinyl, Starite System 3 DE filter 37 sqft, Autopilot Digi 220 SWG
    38,251
    Re: Floating pool liner magically disappears
    Running the main pump in the pool would not have anything to do with the groundwater removal.
    You would need a dry well with a submersible pump. I don't think it would be normal to have a pool pump used to remove ground water.
    Jun 2015
    N Tonawanda, NY
    469
    Keep the pool as full as possible. I imagine it already is so what I'm really saying is don't pump any water out of it.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Aug 2015
    Spartanburg, SC
    39
    Oh ok got you. Well any explanation or ideas as to why the vinyl liner seems to be back to "normal" when the rain hasn't let up at all? This is really confusing the heck out of me...
    And yes my pool is pretty full....almost at the top of my skimmer.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Welcome!
    The phenom could be as simple as whatever drainage system there is on the property having had a chance to catch up a bit even with the continued rain.
    Re:
    While JB's correct that its not normal, I in fact have this very thing But it is not automatic. You must close off the main drain and skimmer lines and open the sump line in order to pump out the sump that is below the deep end. In that case, on your equipment pad with no spa, you would have 3 obvious lines coming in with 2-way valves. If you psy a pic we could take a guess.
    In other approaches to water table management, I have heard of underground auto pumps in the sump right under the deep end, but a drawback of those is that the motors can burn out and then they become impossible to service without ripping up the pool.
    Other (better) configurations will run pipe from under the deep end to a nearby sump with auto pump. You could have that.
    It would be worth seeing if you can locate the original pool builder and ask what measures, if any, they took for groundwater management. Its a good thing to know one wa or the other, though ultimately (unless you do have your pump plumbed to a sump) there's nothing to do bu wait for the water table to recede
    Fingers crosses for minimal liner shenanigans in the mean time
    Here's a pic I found of the "piped deep end sump to pumped sump" -- if your water table is always high, they might have done this:
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Aug 2015
    Spartanburg, SC
    39
    Swampwoman thanks for your reply. So if my setup is like the one in your picture then I should see water being discharged somewhere nearby correct?
    38,251
    One pump can NOT circulate the water in the pool and pump away ground water at the same time. You would need the extra valving setup that she described.
    If you are talking about a submersible pump in a well point, then you should be able to see the opening to access the well point.
