Thread: Pump making noise and vibrating, might want to look for this
    Mar 2015
    Las Vegas NV
    460
    One of my subs was over last week showing a perspective customer some work he'd done and he commented on a very soft noise my pump was making and the fact that it was vibrating. He said I should call Pentair and have them come out and look at it as it sounded like a shaft issue.
    Called Pentair and the support person said I should power down my panel, remove my pump basket and reach in towards the impeller as it sounded as if something was wedged in there. I thought no way, how would something get in there. Well sure enough she was right. I pulled out what I can only describe as a golf ball size hair ball made-up of cr&p that lands in my pool. I have no idea how it made it through my basket and grew there in front of the impeller.
    So, as part of my regular maintenance I'm going to start feeling back there for cr&p couple times a year.
    Here's a question for the experts, do you think I've harmed my pump at all? My guess is it's been running for weeks like that.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    JoyfulNoise's Avatar
    May 2015
    13,252
    Nope. Unless it contains rocks I'm sure your impeller is fine
    Happen to me when I ran my suction side cleaner without a leaf canister inline. Not only did the mesquite needles completely plug up my suction line, but the impeller was jammed up with them.
    If you look at a diagram of what an impeller looks like, you can easily see how and why smallish sized debris is bad for them.
    Pro-tip : put skimmer socks on your skimmer basket and use a leaf trap on any vacuum/suction line.
    Matt
    Mar 2015
    Las Vegas NV
    460
    Re: Pump making noise and vibrating, might want to look for this
    No rocks, just plam silk type stuff, a couple of leaves etc. that formed a soft ball.
    I have a canister on my vac, I'll have to look into skimmer socks. Thanks for the tip!
