Thread: Help! Need advice closing pool replacing stuff next year?
    Aug 2015
    Boston, MA
    32
    Hello all. I had a similar post but today is the day for me to do this all. Wife and I have our first pool and next season we are going to replace the vinyl liner and I may also replace the DE filter as well. Let the pool go about 3 weeks ago and its totally green with lot of debris in it and I live in the Northeast getting buried with rain right now. I am need to drain some out for sure and I am thinking of draining it below the skimmers. If I use the multi valve port waste cycle that will bypass the grids I assume. What would you do? Clean as much debris as I can from the pool just run the waste cycle for a while. Then what do they do at closing that I may have to have done anyway aka so the pipes dont freeze here in the northeast etc? I assume I just cant cover the thing up and wait right?
    IG 15 X 30 Rectangle Vinyl Liner Built 1994
    Hayward DE 3620 Vertical Pro Grid
    AquaCal Heat Pump
    18K gallons
    Jun 2014
    15,066
    Re: Help! Need advice closing pool replacing stuff next year?
    Well, if your pool is an in-ground, then you'll want to follow this page Pool School - Closing an In Ground Pool. This will tell you what to do to protect your lines and equipment. Unfortunately though, a green pool now means a worse pool in the spring. Do you plan on attempting to clear the green before you close? If so, you'll need some time to complete a SLAM via Pool School - SLAM - Shock Level And Maintain. If done properly, it may take a few days, or may take a week or two depending upon how bad your water is. I know you're racing the clock with the weather, but there's just no magic formula to clear the green. Just good old-fashioned bleach, patience, and consistency. Let us know if you have any other questions.
    Apr 2012
    151
    If he is getting a new liner anyway, the pool will have to be drained...so, I would say drain it down and let it go. Pump it out in the spring and replace the liner, start from new.
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
