Thread: Blowing out the lines
    Oct 2015
    Uniontown
    9
    I cannot remember how I blew out the lines the last two years! I have a sand filter with 2 pipes, one to the main drain and one to the water return. Every time I try to blow air in thru the filter basket nothing happens. What am I doing wrong?
    Apr 2010
    Central NJ
    227
    Re: Blowing out the lines
    First, do you have your multivalve in filter mode? Second, you need to close one of the pipes and divert all your air through the other? Third, have you removed anything other than through where you are blowing in the air?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Oct 2015
    Uniontown
    9
    The filter plug is out but that shouldn't matter cause I'm blowing the other way.
