Should Inlet Check Valve Hold Water Overnight?
May 3, 2015
206
Moorpark, CA
I have a check valve on the inlet side of the main pump. When the pump starts up after sitting overnight, there is a lot of air in the system. I suspect water is back flowing through the check valve overnight. I have small leaks at the heater inlet/outlet and the booster pump inlet. I suspect air is getting in there as it backflows through the check valve.
Should the check valve seal be good enough to prevent all water flow overnight?
