Thread: Question about blowing out equipment after lines are done
    I am closing the pool this afternoon and couldn't remember the order in which I should remove the equipment plugs (if it matters) once all the returns and supplies have been plugged.
    For example, Should I relieve pressure/drain the filter first, then remove the Polaris plugs, then the heater plugs? I assume the pump plugs are last to be taken out as that is where I blow from.
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    Re: Question about blowing out equipment after lines are done
    Any order is fine.
    Support the site
    Thanks James....thought so, but just wanted to make sure
