Results 1 to 10 of 10
Thread: My liner is bulging
    Oct 2015
    Uniontown
    9
    My liner is bulging
    I let water out of my pool to begin to close. I took it right under the water returns and when I checked on it the side from which the water is draining has a bulging liner from all the water!!😧 Please tell me it will return back to normal once the ground absorbs it back😲😲 I'm practically having an anxiety attack right now! Help!
    Aug 2014
    Northern IL
    4,615
    Re: My liner is bulging
    Arg! Quick thoughts:
    If you were draining anywhere near the pool, the water is emptying behind it. Can you dig a trench anywhere to siphon it off FAR away and lower than the pool water level? If not, you could pop the liner below the coping and siphon from there. Use a squeegie if wrinkles start to form. If I have some more ideas I will be back.
    Oct 2015
    Uniontown
    9
    You don't think it'll just drain away?
    Aug 2014
    Northern IL
    4,615
    Uh, not sure. Sometimes you get lucky, sometimes not. You could keep an eye on it and see if the bulge grows OR GETS DEEPER and proceed from there. If it gets deeper (water sinking), I would get it out of there. How big is the bulge?
    Oct 2015
    Uniontown
    9
    It is well below the water line. And it is not effecting the top of the liner at all. We had slot of rain this week and I have a former groundhog that burrowed under concrete so I'm sure those two things contributed to my problem. Should I just call a pool person to check it out? Are there any long term affects? Will this be more likely to happen again?
    Oct 2015
    Uniontown
    9
    I should clarify. The bulges are from the floor up.
    Aug 2014
    Northern IL
    4,615
    Long term effects? When the water recedes, you could get lucky or could end up with wrinkles in your liner. If the bulge is really large, it could continue to expand and cause an inversion. Can you post a pic?
    Aug 2014
    Northern IL
    4,615
    Saw that it's better. Don't relax your vigil.
    Aug 2014
    Northern IL
    4,615
    What's up? Or down?
    Aug 2014
    Northern IL
    4,615
    How did things work out?
