Thread: Water Pumping out continuously when I disconnect Intellichlor
    May 2015
    Raleigh, NC
    9
    OK this may sound dumb, but I am trying to acid wash my intellichlor IC-40 but when I disconnect it water comes out of the pipe continuously. I thought it would end but after 10 mins it still comes out like crazy (I was giving it 10 mins to acid wash..but also I seem to have failed at that as no bubbling occurred and the intellichlor trips my breaker immediately). Any idea why the water would still be coming out of that pipe? I flipped all of the circuit breakers so nothing had power. I have 2 valves going to my pump and shut both off. I set my filter to closed. Anything I'm missing?
    Thanks!
    Greg
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,178
    Re: Water Pumping out continuously when I disconnect Intellichlor
    Welcome to TFP!
    I'm going to assume the IC is installed below the level of the pool. To remove it you need valves in the return lines. Right now when you remove it the water is probably flowing backwards from the returns. Just shutting the suction side and the pump down won't stop the water flow from the return side.
    Support the site
    May 2015
    Raleigh, NC
    9
    Hmm yeah I am learning a lot more as I go. Surprisingly it actually looks to me like it is above the pool level...but pretty close so maybe I'm wrong. So I've figured out that when I disconnect the IC40 the water is running backwards from the booster pump, any idea if there's a way to shut that valve off from the booster pump itself (I don't seem to have a valve on the piping to or from the booster pump)? The configuration is pipe from pool to booster pump, then booster pump has a return pipe that joins with the return from the IC40 (so they make a T and then go back to the pool). I haven't tried this yet but next time I disconnect it I'm going to pull the cleaner out of the pool to see if that stops the flow too.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Pictures would really help here, I'm sure!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    Raleigh, NC
    9
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    You. Could try a couple of number 11 winter plugs while you're cleaning the cell.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
