Thread: Antifreeze
    Jul 2015
    Dayton/Maryland
    83
    Antifreeze
    Hi All,
    I am closing my pool. Is this antifreeze suitable for pool closing?
    http://www.walmart.com/ip/Prestone-R...reeze/16213488
    --Yang
    2003 Build 20K gallon salt water gunite IG pool, Taylor 2006 test kit, Pentair 011018 IntelliFlo Variable Speed Pump, Pentair IntelliChlor IC40 SWG, Aquabot ABTTJET Turbo T Jet Robot
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Antifreeze
    As long as it's propylene glycol based, that will work. Looks like that's what it is. Ethylene glycol is engine antifreeze which is a no-no for pools.
    Isolated Spa - 345 Gallons
